Thread: Rcently bought a 2007 series 3, SE diesel
    Oct 2008
    Hunter Valley.
    First question;
    Why are the threads in reverse order, and how do I fix that.
    2. My drivers door sometimes won't unlock, even when the others are unlocked. At first I thought it might be poor remote management, but it happens haphazardly. Not to mention when it is most inconvenient to climb in from the passenger side.
    3. The vendor provided a box with this in it. What is it?
    part # 4R8Q-6600-AC, with U1NDA beneath it.
    Aug 2010
    Welcome Beerdead,
    1 - Live with it!
    2 - See a Stealer
    3 - A photo would help!
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    sheerluck Guest
    Quote Originally Posted by Beerdead View Post
    First question;
    The threads are in order from newest to oldest. And you can change that in User CP, Edit Options.
    New driver's door lock module required.
    Oil pump housing.
    Hope that helps!
    Last edited by sheerluck; 11th September 2013 at 05:47 PM. Reason: Update for accurate info
    Oct 2008
    Hunter Valley.
    ~Rich~I added photos but they haven't come through.
    Thanks sheerluck.
    Not sure if I'm happy about having an oil pump housing as part of the sale!
    sheerluck Guest
    I would be. It's a couple of hundred bucks worth.
    Oct 2008
    Hunter Valley.
    Additionally
    Am considering having a Mitchell Bros 'Air Off Kit' fitted for tyre re-inflation.
    Any feedback re these?
    Aug 2010
    I have one, I'd recommend an ARB compressor under the bonnet instead. ( I have both) The problem with the air off kit is it does not supply enough air to reinflate all tyres and it takes too long for the compressor to refill the tank.
    Your Disco may not have the required bung on the front of the air tank either. On latter models it was removed.
