Results 1 to 10 of 14
Thread: Cruise control issue
    Sep 2013
    Launceston, Tasmania
    Cool Cruise control issue
    Hi,
    I'm new to land rovers and this site.
    So I bought my car (95 Discovery v8 manual) just over a week ago and the cruise control hasn't worked at all since I've had it. I checked all the vacuum hoses and they seem to be fine so I hooked a vacuum hose directly from the vacuum motor to the part that moves the throttle and connected it directly to the battery and it doesn't seem to have the sucking power to do anything more than slightly shrink the rubber thing. Is it possible the vacuum motor needs replacing? I don't know much about it all but hopefully it's something simple. Also the light does come on when I press the cruise control button.
    Gosnells
    The RAVE manual is your best friend.
    Try this link... Dave's Interesting Things - Rave I
    Follow the trouble-shooting proceedures and you will find the problem.
    Sep 2013
    Thanks. I have that already and had a quick look. Guess I'll go back and have a proper look.
    Feb 2012
    Mundaring, WA
    Hi Dtripp,
    I'll be stunned if its not the vacuum motor itself. Unsure why but super common for them to fail. I have had two in three years and my third one has been trouble free for 6 months or so..touch wood! Some wreckers will let you test one before paying and driving away with it. Make sure you do as the second one I brought was already buggered
    Sep 2013
    I'm assuming that when you hook the motor up to the battery and a vacuum hose directly to the thing at the throttle it should open the throttle all the way then? Mine doesn't move it at all. And there's no air leaks anywhere either.
    Muel Guest
    i have a cruise control issue too. found a t-piece leading back to the vacuum servo at the throttle plate floating in the breeze and not much else. does anyone have the vacuum diagrams?
    Sep 2013
    Mine was like that too to start with. From the t-piece one should go to the thing at the throttle, one to the vacuum pump underneath the jack, and one through the firewall on the drivers side. From there I'm not completely sure where it goes though.
    cruizin33 Guest
    Ours stopped working when leaving melb for qld road trip. Had a look on the way but drove to Qld without cruise control. Fixed once we arrived in Qld,found a plastic t-piece had obstruction in it,just enough to render cruise useless. Also had typical split vacum lines in past.
    Blairgowrie, Vic
    ....through the firewall and onto the brake switch/vacuum switch. It's a manual? Then to the clutch switch as well.
    The switch port faces towards the rear of the vehicle.
    Make sure you get vacuum line when you replace the hose.
    And if you need to replace the vacuum pump, one from a EA-EF Falcon will do the job for you. Same Hella bit with a small change to the wiring plug.
    Pete
    Dizzie, 08 D3 TDV6 SE
    Gosnells
    By all means remove the vacuum switches on the brake / clutch to test them.... because it's easier that way... then put them back and test them again.
    - which is where I found one of my problems.
    Would'nt have happened if I'd exactly followed the RAVE proceedure...
