Results 1 to 10 of 23
Thread: GPS-Tablet set up fro 2104
    Jan 2010
    Does any forum member run a newer GPS linked to a tablet. One of the main questions I have is if the smaller new GPS units have a similar reception as their bigger counterparts with separate antennas.
    Thank you for any inputs.
    Jan 2013
    Penrith
    Quote Originally Posted by 100inch View Post
    Dont tablets come with inbuilt GPS?.... saying that I tried to bluetooth my sat reciever to my tablet but it failed Android could not recognize it and could not find drivers for it, the inbuilt GPS on mine works better anyway.
    Jan 2010
    True, but as far as I know they are based on the phone network data. Or I am wrong?
    Jan 2013
    Penrith
    Thats incorrect they are stand alone gps, do you have a map app installed like ozi or hema
    Feb 2011
    Brunswick, Victoria
    The GPS receiver is just hardware that feeds positioning data to an application that requests it.
    It depends entirely on what software you use with it as to whether you need phone coverage. If you use something like Google maps, you'd need a phone network. On the other hand if you use off-line mapping apps like OziExplorer, Memory Map, or turn by turn apps which use local copies of the mapping like Sygic then you can run without a network connection.
    Paul
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Kevin B View Post
    Not all tablets have a proper GPS chipset and those with a 3/4G capability may only use the mobile network for triangulation.
    There are tablets with a true gps chip built in .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2013
    Penrith
    i have 2 Tablets, an Aldi one and a Samsung one and they both have built in Chipsets, i was unaware there were tablets that didnt have this, thanks
    PTC Guest
    Running a tablet as my mapping in the old car. I had a Bluetooth GPS mounted on the roofrack, hard wired into the car's power and then connected to my tablet. I found this the best as the gps in my tablet took awhile to boot up and refresh my position while moving.
    Jan 2010
    That is the setup I am thinking of. A smaller GPS feeding into the tablet. What type of GPS and tablet do you use, PTC?
    PTC Guest
    It was like the one that Rudi sells here. Though it had Bluetooth as well.
    Navrun - The Ultimate 4WD Challenge
    Sorry i don't know the brand anymore as i sold the unit when i smashed my tablet. I need to look into a new one myself. As i am hoping to set up a Ram Mount and Tablet again in the new car.
