Page 1 of 8 123 ... LastLast
Results 1 to 10 of 76
Thread: TD5 taking a while to start
    Jul 2013
    So can't say it's been smooth sailing so far... and this is probably the worst question to ask, but.....
    The last couple of starts the engine doesn't fire first go, as has been the case once the glow plug light goes out. Instead the engine winds over and over.
    That last time at work, I started pumping the accelerator ( not sure this is effective??? )
    Since owning this car the head was done, lots of hoses replaced, the starter motor contacts replaced (that was done by me following tutes here and on discovery2.co.uk ( that's going to hurt when that site closes down! )) so I'm hoping someone can give me a few places to look at first before taking it to the mechanic, which given the dire financial position I'm in after the $5k spent last time it was there, I'm reluctant to do just now.
    Thankfully I haven't sold my car yet. Guess I can just drive it and leave the Disco in the driveway until I can sell my first born.
    fuel pump
    fuel pump relay
    fuel pressure regulator
    crank angle sensor
    they're the common ones
    Jul 2013
    fuel pump
    fuel pump relay
    crank angle sensor
    Thanks. Way out of my league...
    Guess it's off to the mechanic.
    jed Guest
    How old is your battery. Mine became difficult to start, especially from cold. Engine spun over fine, just wouldn't catch. Something to do with the voltage drop being too much to power the ecu /injectors. Worth a try if you can borrow a good one. Changed mine for a Lucas 664 6 months ago and it's been fine since.
    Jul 2013
    Ok based on the start this morning and that the fuel pump making odd noises I have a start point.
    Time to find a tutorial on how to do it.
    May 2010
    brighton, brisbane
    Quote Originally Posted by plaven View Post
    Mate, buy a RAVE dvd from the MARKET section here, start doing as much of your own maintenance as you can, Get to know your vehicle. You'll save heaps, & as they say, you'll never never know, if you never never try Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Jul 2013
    Quote Originally Posted by bob10 View Post
    Thanks Bob. I have a RAVE CD already.
    I've found a run down on aulro and now watching a youtube video about how to get to the fuel tank.
    I'll have a read through the RAVE CD shortly.
    Once done it's time to have a crack...
    Only the 2nd time with tools in hand doing something I've never done before. Go figure.
    Jan 2012
    NSW
    You don't need to take the fuel tank out to get at the pump.
    I have just replaced mine and you can get at it from the top by just removing the trim.
    Look in the rave manual there are good step by step instructions there and there are also tutorials if you search for them.
    Good luck Mick
    Jul 2013
    Quote Originally Posted by Husky View Post
    Good luck Mick
    Thanks Mick.
    Watched a youtube video: Land Rover Discovery 2 Fuel Pump Install - YouTube
    Read this post on aulro: http://www.aulro.com/afvb/discovery-...-pump-td5.html
    And read through the RAVE CD... all I need now is the new pump and the weekend to roll around.
    Pete.
    Jan 2012
    NSW
    I got my pump from the Uk it was $300 or $400 cheaper,
    But it takes 5 to 7 days to get here (from my previous experience)
