18th September 2013, 04:41 PM
Nanocom Reading ACCel Way 3 question
Hi,
I was reading through NANOCOM's FUNCTIONS DESCRIPTION MANUAL.
According to this extract I should be getting a similar value for WAY 2 and WAY3.
However On:
Throttle closed.
WAY 1 I get 0.69
WAY 2 I get 4.35
WAY 3 I get a constant reading of 5v.
Throttle to floor
WAY 1 I get 4.6
WAY 2 I get 0.4
Supply is 5v
So, is this extract correct?
Mine is running a NNN ECU modified MAP. Does that make a difference?
Thoughts...
ACCEL. WAY 1(V) - about 0.3V with the pedal released, about 4.7V with pedal to the maximum position
ACCEL. WAY 2(V) - about 4.7V with the pedal released, about 0.3V with pedal to the maximum position
ACCEL. WAY 3(V) – this track must have values very near to the second track.
