in order to reset you will need a nancom this will also give you the fault code that caused them to come on in the first place cheers ken
Hi Guys.
Today in just driving around town in my 2008 defender the traction control and ABS lights came on. What sort of problem could this indicate or what should i do to reset these. Any help would be appreciated.
Eck
 ChatterBox
						Supporter
						ChatterBox
						Supporterin order to reset you will need a nancom this will also give you the fault code that caused them to come on in the first place cheers ken
have a good one :D ken :wasntme:
MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
1996 D1 300TDI GONE
08 ford ranger c/c
WRECKING DISCOVERY 2
PM ME FOR WHAT YOU ARE LOOKING FOR
Hey Eck,
I had this same problem in mine, had it in a couple of time as both lights would come on randomly. They checked all connections between the wheels and computer to no avail. Eventually I narrowed it to the rear drivers side, I traced the cable and found it had broken free of a cable tie next to the hand brake drum and it had rubbed through and was causing a short. Cut and soldered the wires problem solved. Not sure about anything it could be though.
Cheers Lucas.
I had a similar issue on an 07 defender and found it to be the earth cable for the abs/traction control that attaches to the gearbox was loose.
