                                                25th September 2013, 07:29 AM
			Fuel return pipe
					Hi folks
 My Son recently replaced his fuel tank on his 1993 turbo diesel Defender.
 Unfortunately, the fuel return pipe is leaking at the tank seal.
 It is a real pain in the butt to remove the tank again so my question is...
 Is there an inspection plate in the body above the tank to get to the pipe?
 I need to ask as he has a set of drawers in the rear so, without pulling the drawers out, he can't see if there is or isn't a plate.
                                                25th September 2013, 08:01 AM
					HI
 unless there been a inspection plate fitted  bad news have to take the tank out
 mulgo  have a inspection kit  very easy to fit
 drawer system may make it a bit hard to fit but ive managed it on mime 2002td5 defender
 good luck
 hans
                                                26th September 2013, 07:01 AM
					Hmm... bummer!
 Thanks Hans. I appreciate your help.
                                                26th September 2013, 12:48 PM
                                                #4
					I did the exactly the same thing. Replaced the tank and it leaks from the return line when I fill up. Solution ; don't fill up to the top. Does your leak all the time?
 Tank removal is simple enough but you need fingers like an octopus to get the tank back in. Good luck
                                                26th September 2013, 04:58 PM
                                                #5
					Had the same problem with the new tank I fitted, I removed the tank again removed the cork seal they provided and just used gasket goo, haven't had a problem since.
 To answer your question there is no inspection plate from factory.
 Aaron & Jacinta 1994 300Tdi Defender
                                                26th September 2013, 05:00 PM
                                                #6
					Thanks A & J, I think I'll do the same but might cut an inspection opening/ plate in.
 cheers Gerald
