                                                26th September 2013, 02:57 PM
			 TD5 Fuel Filter Water Sensor problem TD5 Fuel Filter Water Sensor problem
					Hi To All,
 Just wanted to share a little bit of information re the water sensor located at the bottom of the fuel filter.  After just changing the fuel filter I started her up and found the water light was on all the time.  Did a little investigating and found the fault was due to the sensor tip touching a metal section located inside the filter.  This appears to only effect the Bearmach ESR4686R (Also labelled ESR4686 <C>) filters and is due to the internal construction of the filter.  The original and Britpart filters are not a problem.
                                                26th September 2013, 03:48 PM
			Fuel filter td5
					This is also a problem with ryco and other filters I contactad Land Rover they said disconect it as we have had a lot of problems with these's so I rang my machanic he told me the same as they only deal with Land Rover I disconected it problem solved. so I rang my machanic he told me the same as they only deal with Land Rover I disconected it problem solved.
