                                                27th September 2013, 10:29 PM
			Preventative for Puma (115k)
					Aside from the standard log book servicing that is done.
 What sort of other things should I be looking at replacing at this age?
 Cooling system etc?
 Im all for over servicing!
 Edit - What about replace all cooling hoses? Im apprehensive, I once got all my hoses on my tD5 done without inquiring about cost.. Quite a few hoses on them :P $$$
                                                28th September 2013, 05:51 AM
					Change and flush brake fluid.   Abs bits are not cheap.
                                                28th September 2013, 09:25 PM
					At 115k you might be up for some shocks and suspension rubbers and bushes.  You don't have too, but you will notice the new ride.
 I just had much of my suspension re bushed with rubber at 90K, and it drives like new again.
 My rough plans is
 Coolant and brake fluid every 50K
 Trans oil every 20K
 Diff oil every 12 months.
 G box every 50K
 Hoses.... I'm hoping for 150K.  Installed a low water alarm for $160
 shock rubbers every 12 months if hard driving or touring, 2 years if normal
 Shocks at 2 to 250 thousand.  Only because they are big koni's.
 suspension rubbers, every 100K
 power steer fluid ?
 wheel bearings and seals every 100K
 serpentine and air con belt, 150K
 Jason
 2010 130 TDCi
