Results 1 to 8 of 8
Thread: I've rebuilt the 300 TDI and can't get it to start. Do you know which injector pipe
    Jul 2012
    Gaborone, Botswana
    connects to cylinder 1 (seen from the distributor face of the DIP).
    Geelong, VIC
    The one closest to the engine block (ie 9 o'clock position looking forward).
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Didge Guest
    Hi Jode, just had a look.
    Now, if you count your cylinders from front of car to rear of car as 1 - 4 and if you look (from rear of pump looking towards front of car) at the injector pipes as being positioned as the hours on a clock, mine are configured as follows
    9 o'clock goes to cylinder 1
    12 o'clock goes to cylinder 2
    3 o'clock goes to cylinder 4
    6 o'clock goes to cylinder 3
    Jul 2012
    Gaborone, Botswana
    Thanks, guys, the pipes are as they should be. The problem must be the timing (I thought it was spot on...).
    Jode
    in the wild New England, NSW
    Check that you power connector to the pump shut-off solenoid has 12v power.
    Didge Guest
    Having trouble sleeping Jode??? Ahh, just noticed where you are
    Jan 2012
    Melbourne, Victoria
    Hi there Jode,
    I rebuilt my 300Tdi a month or two ago and had the same problem of not being able to start it, after consulting with the trusty Land Rover Encyclopaedia of Knowledge (aka Aulro) and having yet another look at the timing I found that I had actually gotten the injector pump timing very slightly out despite having gone over it twice already, I did get it started after a LOT of trying but it ran quite rough and blew white smoke, when I adjusted the pump timing the difference was immediately noticeable, it was easy to start and back to running smooth like a rebuilt engine should, even if its a frosty morning without glowing it first it fires on the second or third turn over of the engine.
    So going from my experience I would say check the timing Good luck and have fun!
    Cheers, Remo
    Dec 2009
    Williamstown, Barossa, SA
    On the subject of bleeding a rotary pump, select the highest I hector outlet on the pump (No 2 on a Tdi?) and bleed it at this injector.
