Results 1 to 10 of 12
Thread: Late model VDO Auxiliary Fan into early TD6
    May 2006
    Carlton, Melbourne
    As some may know, I've had trouble with the Aux Fan (electric condenser fan in front of the radiator) The original one was shot, I bought an aftermarket one from The States, it lasted a week!
    The original ones were a faulty design, never up to the job, and the same fans fitted to BMW's were subject to a recall (possible fire risk).
    The problem with them is they have 9 speeds they can run on, and are controlled by an ECU in the car that sends a signal to the motor via a control signal cable dependant on several things, mainly the aircon refrigerant pressure, and the actual speed controller is built in to the motor. The other 2 thick wires are a permanent 12V supply, so not any fan/motor assy will work properly.
    Anyway, to cut a really long story shorter, I saw a late model BMW (2007-2009 5-Series) made by VDO on e-bay, and got it for $80! These fans are fitted to the later Rangies too. They have 2 thick and one thin wire, so I thought "what the hell, I'll try it and see if it works.
    It does!!!
    The colour coding is different:
    the old Blue wire connects to the new Red
    the old Brown wire connects to the new Black
    the old thin Black wire connects to the new thin White.
    I just cut the old cable off near the motor, cut the new cable off near the plug and joined them together.
    The motors are quite different in diameter, but the fan is spot-on the same size. All I had to do was jigsaw out a 10mm wide ring in the centre of the cowling, and add 3 strips of small bar as clamps to hold it all in place. I als put a little ring of silicone around the contact area of the motor to the plastic to stop any vibration moving anything.
    Just thought I'd share!
    Cheers all,
    Fraser
    May 2008
    Good to know Fraser ,just another little job to look forward to when it happens to my RR, also good to know you can get a different part to fit with a bit of modification.
    Cheers Deco
    May 2006
    Carlton, Melbourne
    Quote Originally Posted by Declan View Post
    Cheers Deco
    I'm glad I did it, I'm sure it's not good for it on those hot days when the aircon would blow hot air every time I stopped at traffic lights - the pressures must have been through the roof!
    Never heard of the VDO motors failing, so hopefully that's it sorted for good.
    May 2006
    Carlton, Melbourne
    Pictures
    Here are some pictures to show what I've done:
    Just cut out about 10mm all around the inside of the motor hole:
    Closer:
    All assembled with original guard (you can see where I spliced on the old cable too):
    Just put it back in the car, turned the heating on full 'till car was hot inside, then put aircon on full, then covered front grill with a towel, you could hear the motor start, then increase speed as the system pressure increased, then I removed the towel and a few secs later it began to slow (it is only 15 degrees outside)
    Very happy chappy!
    Manly QLD
    Hi Fraser,
    as I now have this issue, what the chance you have a part number to search on?
    thanks
    May 2006
    Carlton, Melbourne
    Quote Originally Posted by harlie View Post
    Hi Fraser,
    thanks
    Harlie, this is the information from the ebay ad, so I can't be sure it's correct:
    BMW part no. 17-42-7540683-01
    Motor is made by Siemens VDO with part number 07260101 02 and is made in Germany.
    I bought it by sight, (I recognised the motor design, and it had 2 thick wires and one really thin wire)
    It's still working a treat too!
    I hope that helps.
    Fraser
    May 2006
    Carlton, Melbourne
    Here's another with the same motor:
    Here
    And here
    and here too!
    Just check the fan blade diameter, as the one I got is exactly the same size, and I'm not sure how to remove the blades, and the blade attachment to the motor is different to the original.
    The one I got the new blades/motor fit perfectly in the old RR cowling as in the pics.
    Best of luck Harlie!
    Fraser
    May 2006
    Carlton, Melbourne
    Harlie, how did you get on?
    It's been a while now including one day of 40 degrees (and I spent most of that day driving with the cab at 22), I can confirm the new fan works a treat!
    Fraser
    Manly QLD
    Hello Mate, happy xmas to all...
    I have not done a thing about it, been working stupid hours last two months up to last Friday. I wanted to do it during the break but have not been organised enough to get a part in - the Rangie really doesn't do much driving in heavy traffic, so to be honest we have't really noticed it's not working - apart from the point that the AC is not cold when the car is started before you move off, like at the beach yesterday sitting in the sun for 3 hrs, once it's moving the cold air flows - probably has the viscous fan running more often too.
    So it's 1 job off the list. Got my trans filter & fluid to do 2 drops, compressor rebuild kit, coolant, PS fluid - just no fan, get 1 in for January.
    Manly QLD
    Hi Fraser,
    Any hints on removing the fan?
    I assume the shroud needs to come out.
    thanks
