Steering relay Ep 90. . Same as diffs and steering box ... Transfer and gear box by the book to ( I'm using penrite clasic ep90)
 Master
						Master
						What oil is used in the steering box located in the chassis
2002 defender 110 , 1955 86 inch
 YarnMaster
						YarnMaster
						Depending on how worn it is, Penrite EP140 semi-fluid grease can also be used, with the added advantage that the crappo cork seal is less likely to leak,
Cheers Charlie
I mixed semi fluid and ep 90 to fix up weeping swivel hub for my roadworthy . Has youre relay got a grease nipple on it?
