Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: BLOODY BRAKES
    Nov 2006
    cardiff ,NEWCASTLE.
    BLOODY BRAKES
    Ok so the wife goes & buys me a disco 1 .. YES she bought me one.. Anyway its always had spongy brakes & the 2 rubbers under the fluid resivor where leaking.. So I drained all the fluid & replaced the 2 rubbers & fitted all new brake pads.. Then I bleed the brakes CAR NOT RUNNING, & NON ABS & we gets a perfect pedal hard as a rock, Sweet.. So I start the car & the brakes are still SPONGY. So I jumps on the forum & read everything I could find & seems I am bleeding the brakes correctly . So I read on threw more threads , & someone had the same problem as me & was told it was the booster So I have gone out today & bought a new one. BUT I desided to rebleed the brakes again since the car has been started & moved , So I bled each nipple 5 times every nipple & not one bubble anywhere. So I starts the car again & still the same..I have checked all flexible hoses with the car running & not running theres no swelling at all so its not those.. So I will replace the booster tomorrow BUT I don't want to drain the system & rebleed it all.. So was wondering if anyone has changed out the booster without taking the master cylinder off. I am going to try but just thought someone here may have done it & can tell me about it.. When I built the green series I made the brake pipes a tad longer near the master cylinder just in case I ever needed to change out the booster.. Also the car is a 1992 3.5 EFI 5 speed. IS there anything else I should be looking for..So if anyone has any ideas what to look for now & anything else I should be looking at.. Also the brake light switch don't work properly as the lights stay on. I read someone has same problem so had a look at my switch it doesn't seem to be adjustable like what I read about so ill either need to replace or do what others have done & put a small screw in the end of it .. Anyway I hope use can understand my ramblings & whats going on.
    Thanks for any help guys
    Cheers Jason..
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    Nov 2006
    cardiff ,NEWCASTLE.
    Oh yeah the car is registered & ive spend a heap on doing it up all so I can have a pretty garden ornament. So yeah need to sort the brakes..
    Thanks Jason..
    All pics I have are in the emmbaracement thread if use are interested . Bout 10 pages back from the end..
    I'm starting to HATE this car so much & I haven't even had the chance to drive the bloody thing,,. GGGGGRRRRRRRRRRRR
    JASON & KAREN
    Kiwiland
    It's not the booster. A booster not working gives a hard pedal, not a soft one.
    Have you taken it out for a drive? It could be your brakes are fine but expectations somewhat different.
    Nov 2006
    cardiff ,NEWCASTLE.
    Quote Originally Posted by Dougal View Post
    Na haven't driven yet brakes don't work well enough for me to drive.. Pedal is perfect when engine not running & only spongy when running.. I read someone had same problem as me & they where told the booster wasn't working so I was just going off what they was told.. I have never driven a disco before so have no idea as to what a good pedal feels like BUT this pedal doesn't feel right at all..way to spongy yet I can get any air out of the lines anymore just nice clean fluid with no bubbles & ive bled them heaps so I know theres no air in them as I have put 3 BOTTLES of fluid threw the system as I like to be certain..
    Thanks Jason
    JASON & KAREN
    Kiwiland
    Quote Originally Posted by banjo View Post
    Thanks Jason
    If you haven't driven it, then how do you know they aren't good enough to drive it?
    On my rangie a rock hard pedal with the engine off is the sign the bleed was good.
    Nov 2006
    cardiff ,NEWCASTLE.
    Have moved it around the yard a bit & it doesn't pull up very good.. YES this is my first modern landy but after close to 25 years building breaking & fixing landrovers one would think I would have some idea as to what feels right & what doesn't.. Not being nasty to you at all just saying this isn't my first dance with brakes.. & these don't feel right at all.. YES the pedal is PERFECT after I bled them & the car not running but when I start it the pedal is just way to spongy.. The pedal IMO should still be hard to some degree when the car is running & the brakes have vacumn..
    After I have T I will find the other threads I read & post a link of what I have read & why I got the new booster. Someone else had the EXACT same problem as mine & was told the booster is leaking.. ONLY GOING ON WHAT I HAVE READ.. BUT since this is my first modern landy with disc brakes all round I thought I would ask for sugestions..
    JASON & KAREN
    Nov 2006
    cardiff ,NEWCASTLE.
    This thread is the same as what im having
    http://www.aulro.com/afvb/discovery-...gy-brakes.html
    And this thread tells me I am bleeding them all in the correct way.
    http://www.aulro.com/afvb/discovery-...-sequence.html
    And this thread tell me about the brake light switch problem i'm having is the same as this persons.
    http://www.aulro.com/afvb/discovery-...ht-switch.html
    JASON & KAREN
    Dec 2010
    nsw
    You make mention that all pads were replaced. I recently replaced all my pads and can say for certain that the pedal will feel very spongey until you take it for a run and let them bed in a little. Mine took probably the first 100km to feel their best but after a short drive improved dramaticallyThis is normal and will vary depending on the condition of the disc surface and how you drive. Interestingly the pads I fitted advised against any bedding in process , rather just to avoid hard breaking for the first 100km.
    Kiwiland
    Quote Originally Posted by 98discovery View Post
    Indeed. New pads on worn rotors wil feel a bit mushy until they wear to fit the not-flat rotor surface.
    Nov 2006
    cardiff ,NEWCASTLE.
    I will take it for a small drive this morning & see how it goes before I change out the booster. Can try it anyway..
    JASON & KAREN
