Thread: fishing waypoints
    darwin
    fishing waypoints
    I have been given 15 A3 pages of gps fishing points for around here, what is the simplest way of saving them digitally so that i can load them into my lowrance gps. I also use ozi explorer in the landy but i guess it wont float so that is not a big issue.do i just type them into an excell or is there a special program.
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Williams West Aust
    Lewy.
    May be worth posting this in the fishing shack
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    May 2002
    Heathcote (in "The Shire")
    If your lowrance GPS is supported by Ozi, I'd create an excel csv file with the right format that will allow you to directly upload them via Ozi to your GPS
    Martyn
    darwin
    Bushie,would i need to type the complete reference into one cell or divide it into two.This is all new to me.
    Darwin
    03 disco 2a td5
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    May 2002
    The easiest way would be to create a dummy waypoint file in Ozi, export it as a txt file, then open as a csv in excel, you can then add any other lines (waypoints) that you need.
    Save the file either as text or csv and then open in Ozi and you should see all the waypoints displayed.
    Martyn
    Torres Straits
    You have a few options!
    gpsbabel will let you batch waypoints and directly upload them to your lowrance
    Plenty of other options using open source software like Qlandkarte GT
    Which ever way you go it is handy to have marine chart software on your computer so you can route plan and back up waypoints etc etc. Marine gps untis get a hard time in salt and wet environment, having an easy digital backup of points is pretty important.
    S
    Moruya Heads/Sth. Coast, NSW
    You don't need a GPS, use the Irish method, when you find a good fishing spot just put an X on the side of the boat, LOL, Regards Frank.
