Results 1 to 8 of 8
Thread: Computer aint Computing
    Gold Coast QLD
    Hi guys
    The home computer wont fire up after it froze on swmbo on friday, it only makes 3 loud long beeps and then sits there doing nothing, the scrern comes up no input detected, it runs windows xp. Any ideas?
    Thx Ian
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
    sheerluck Guest
    3 long beeps normally means memory problems. If you have multiple sticks of RAM in there, try removing/replacing them one at a time.
    Just remember to take the usual precautions with ESD, handling, etc.
    St Helena,Melbourne
    4.28 MB
    Time to upgrade .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2013
    Quote Originally Posted by ezyrama View Post
    Hi guys
    Thx Ian
    Hi Ian,
    Disconnect from all power source (basically unplug from all power source) and leave the PC ideal for 30 mins and fire up again This should work as it refreshes CMOS memory . Worse case you might have to open up the cover and lift the small battery on the motherboard and this should resolve the issue..
    If this is all good try booting up again at just as it starts up keep pressing F8 key it should then ask .. Do you want start in safe mode?
    Select the option of safe mode and proceed?
    That's my 2cent worth?
    Happy to assist you further.
    Regards,
    Nav
    Aug 2009
    South Australia
    Please dont listen to the motherboard battery bit. It's not that, and if you are an amateur you could damage things. It is definitely a memory problem.
    Either one of the sticks not seated properly or (less likely) a dead stick.
    It is VERY important to take static precautions when touching ANYTHING inside the case. Leave the power cord plugged in, but turned off at the wall. This way the PC chassis is earthed. If you dont have wrist strap, grab part of the chassis before handling the memory chips. This should remove any static charge from your body.
    Remove each sick in turn - if more than one - then try a restart each time.
    Cleaning the stick contacts is great, but do it carefully!
    Apr 2002
    Bellara 4507
    32.43 MB
    use a soft white style pencil rubber to clean the contacts of the ram... not an ink eraser
    make sure you clean off all the left overs and reseat the ram.
    like said earlier it should be ram
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Sep 2012
    Adelaide Hills
    3 long beeps means you have have been downloading too much porn and the memory is corrupted as a result.
    Gold Coast QLD
    Thanks Guys
    Did the rounds trying a few things but it turned out to be just the power supply. Fitted a newbie and voila! God I'm Good.
    Cheers Ian
