Results 1 to 10 of 19
Thread: Rising temp then returning to normal
    Cracker97 Guest
    Red face Rising temp then returning to normal
    Any help would be great.
    I have posted a thread about this same issue before, but thought it was resolved. After a lot of work and money, I still on random occasions (manly when at low speeds, diff lock in) see a slow climb in temp to just under the upper white line. As I keep driving ( at same speed or load ) the temp will then drop straight back down to normal, below 1/2 way???
    Work to date done by myself and mechanics includes,
    New temp sensor
    New alum radiator
    New thermostat, 88 deg
    New fan
    New thermo fans on A/C
    Engine flush
    Valve replacement to repair engine miss
    3 faulty injectors replaced
    Vacuum advance unit replaced
    Tuned
    New 2.5" exhaust
    After all this I still get an increased temp and fall, about to order a hi flow thermostat, as it only seems to occur under load.
    Can anyone offer anymore clues on what to check next, or recommend a good mechanic to give a once over and test please.
    Thanks in advance
    Cracker
    Jul 2008
    Ballarat, Victoria
    slipped liner or cracked block maybe?
    have you tried a different temperature gauge? the factory one isn't know for its reliability
    Feb 2012
    Parkdale, Melbourne
    Electrical? Maybe an earth problem. Only need a slightly poor connection and the resistance of the sender will appear different to the gauge.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Jan 2013
    Penrith
    I was going to suggest a Aftermarket Temp Guage as well, mine has the same problem, needle rose to almost 3/4 then back to normal, i put in a new aftermarket temp guage and while it still rises the guage only shows it going to 92deg max before it goes back to 88deg, another good investment is a Thermal (laser) Themometer, it gives a good indication of what various parts of your engine are doing.
    Cracker97 Guest
    Smile
    I have been thinking of a proper gauge for while.
    I forgot to add Airtech snorkel as well to the list. I,m doing everything I can to get cool air in and hot out better. Hoping it saves a few litres of petrol as well and a couple of extra HP,s. Sounds bloody great but. Peter at Newcastle Muffler service sure knows how to improve the factories work....
    Cracker
    Cracker97 Guest
    Has anyone added an Engine watchdog?? Are they worth the extra cost over the normal type of temp gauge.
    Cracker97 Guest
    Mar 2011
    South Aust
    Feb 2012
    Parkdale, Melbourne
    I fitted a VDO mechanical temp gauge. Sender is a straight swap without adapters. Just need to mount the 52mm gauge somewhere. Being mechanical it can't suffer from electrical issues.
    - Justin
    Water pump? Genuine? Recently replaced?
