Results 1 to 10 of 16
Thread: Defender soundproofing
    Duncan Guest
    Hi,I recently bought a 2003 Defender and was wondering if anyone has had any experience with soundproofing one.This is my second Landrover having owned a SeriesIII before which is when the love affair began.I'm also interested in any information on the chip upgrade.How much does fuel economy suffer?All experiences appreciated.Safe travelling, Duncan.
    May 2003
    On The Road
    Welcome Duncan,
    not sure in Oz,, but check out LRO mag for websites in Pommyland, they may distribute here.
    If England is so cold,, why do Pommy heaters never work?
    Perth WA
    I found this site, but I dont know if they do mail order.
    http://www.noisekiller.co.uk/home.htm
    some of the testamonials are form the US so they probably do. the only question is how much $$$$?
    Duncan I have a 2002 Defender with home made soundproofing and a Bruce Davis Chip upgrade. I purchased soundproofing material from a place in Brisbane which makes it for boats and just made my own. Seems to work ok. The chip upgrade actually gives better economy well drive as normal because the chip blueprints fuel delivery. However obviously when the extra power is required more fuel is used. Overall though my is just the same although my friends economy has improved (Disco 11)
    Mandurah WA
    Duncan
    If you are serious about driving a defender without hearing much engine or road noise...get the thickest peice of insulation you can find and wrap it around your head with Duc Tape!!
    Seriously, I am looking at trying reduce a bit of the noise as the Defender is our "good" car and the wife bitches a bit (as they all do).
    I am starting with some underbonnet insulation from that mod in Melbourne.
    Then I will be looking at heat/acoustic insulation above the g/box and on the fire wall as the handbrake does get damn hot some time.
    Once I have a go at these I will reassess what need doing.
    Goblin Guest
    Guys,
    I'm dragging this out again as I am also investigating some noise reducing options. Bit of thermal protection around the transmission tunnel and firewall wouldn't go astray either .
    I would like to know how you went.
    I have scoured the internet and found several companies who have produts but I am still in research mode. If anyones want some links, here:
    http://www.lydallautomotive.com/index.cfm
    http://tighitco.com/home.htm
    http://www.soundproofing.org/sales/prices.html
    http://www.hillmanimages.com/912/noise.html
    http://www.dynamat.com/
    http://www.b-quiet.com/
    http://www.shoptheweb.com.au/Electrical/Ac...nsulation.shtml
    http://www.installer.com/noise.html
    http://www.soundguard.com.au/index.htm
    Bracken Ridge, Qld
    Originally posted by lrdef110
    Duncan I have a 2002 Defender with home made soundproofing ... I purchased soundproofing material from a place in Brisbane which makes it for boats and just made my own. Seems to work ok.
    Material from where ?
    Is the insulation inside or outside the cabin ?
    If outside (eg under transmission tunnel) doesn;t it get full of sand or dirt and rubbish ?
    How did you go about 'making' the soundproofing ? Was it just a matter of gluing it on in sheets? What adhesive to use ?
    These answers would no doubt be of interest to others as well as my good self.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Melbourne, mostly
    I have ordered the Noisekiller kit from the UK and am eagerly awaiting its arrival. It is said to reduce idle noise by 4db.
    Also in the garage is a can of bitumen paint. This will go under the wheel arches, and on the doors after I pull the trim off.
    I will do before and after soundmetering tests and keep you all posted. Stock, then soundkit, then paint.
    More info, PM me. Anyone in Melbourne is welcome to come and see what difference it makes to my car when it's done.
    Another good way to decrease noise would be a GKN overdrive. Now I've installed the tacho it seems we're doing an unsightly amount of RPM at 110.
    Goblin Guest
    Robert,
    How much did the kit set you back if I might ask?
    And where or who did you order it from?
    I might just take you up on a peek later. I am in melbourne too.
    Melbourne, mostly
    Originally posted by Goblin
    Robert,
    Prices are on the NK site; use something like www.xe.net/currency/ to convert. Add shipping to that too. steve@noisekiller.co.uk.
    I know you're in Melbourne, you processed my LROCV membership!
    Just emailed them; said it left them this week, should be with me by next weekend. Not good considering I ordered it 4 weeks ago and my card has been charged. But anyway, let's see how it works.
