Results 1 to 8 of 8
Thread: Diff Bearing Preload Setting?
    Sep 2013
    turners beach tasmania
    I'm doing up an LT230T Transfer Case and I have to set the differential bearing preload.
    Can anyone explain how to use all these different tools and dial gauge to set the bearing preload.
    Has anyone out there done it? Can you set it without the tools listed in the manual, like the LRT-41-014/3 Setting Block? LRT-41-014/1 cross bar and LRT-41-014\2 depth block tool
    Does anyone know what weight is required on the spring gauge? I presume it is dragged around the outer edge of the brake drum
    Last edited by defendaroo; 9th October 2013 at 02:30 PM. Reason: more questions added
    Canberra ACT
    I didn't use any special tools - just a piece of string and one of those "fish scales" things. Dont remember the exact specs for this but it should be in the rebuild manual. It was a matter of fitting the front output housing on and off with different shims behind the bearing race until I got the right resistance needed to turn the centre diff assembly. Remember the gasket thickness on the housing and the torque of the bolts will affect this. A trick I used to make this easier was to grind down the outside of the old bearing race to a slighlty smaller diameter so it could be slotted in and out more easily. Once I had a shim which was within the range I replaced the old race with a the new one and checked the resistance again.
    As there are so many shim sizes available I ended up finding one slightly larger than I needed and sanded it down on a flat sanding plate until it was the right thickness. Bit tedious but it worked for me.
    Good luck.
    Adam.
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    When I built my LT230 I used one of Ashcroft's multiple shim kits. Cost me GBP £32 plus a bit of post and it was well worth it. It covered the centre diff and the input gear, although the input went back together with the original shim.
    As Ads mentions, a spring gauge and string will see you right.
    Sep 2013
    Thanks for the advice, I'm still a little confused. Does anyone know what weight is required on the spring gauge? I presume it is dragged around the outer edge of the brake drum . The shim kit wouldn't get here in time unfortunately.
    Jun 2008
    Drouin East, Vic
    Quote Originally Posted by defendaroo View Post
    It's not so much a matter of weight on the spring gauge, you use the spring gauge to pull on the string wrapped around the hub, and observe the reading on the spring gauge (or scale) which is telling you the amount of force you are pulling with. The correct amount of force will be specified in your manual, which I presume you have as you've quoted all the special tool numbers.
    Sep 2013
    My manual doesn't have the spring tensions in it. Is there a weight measurement for it when it's all back together?
    Hay Point
    Rolling resistance for the centre diff is 1.8 to 4.5kg. Use the shim to obtain this figure.
    Cheers......Brian
    1985 110 V8 County
    Canberra ACT
    I second what Bearman just said. Don't however wrap the string around the brake drum though. Needs to be around "the exposed splines of the high/low hub". May seem obvious, but this reading is before you refit the input gear and intermediate gears.
    You probably have the overhaul manual that doesn't list the load to turn specs. Other manuals do, so it may be worth having a google for the other ones online.
