Results 1 to 9 of 9
Thread: Disco rear work light.
    Pilbara WA
    Found this from another forum and think it is a great idea.
    Discovery owners who park their trucks in garages that have low ceilings or doors don't usually have roof racks installed. They have a problem when it comes to extra lights. Up till now there hasn't been any reasonable way to mount any kind of work light at the rear of the truck. Recently I had a brainstorm while installing an Out-Back CB antenna mount on the rear door of my Disco. I made some sketches and fabricated an Out-Back work light mounting bracket that is a perfect solution to the problem. The bracket was simple to make after I worked out the three bends needed to fit over the lip of the door. Here's the drawing and measurements - they are general and you might adjust them to suit yourself. It's fabricated from a piece of 1/8"CRS 2" wide and about 3 ¼" long. Drill the screw holes to suit as you see in the photograph but place the light mounting stud hole about ½" from the front edge of the platform. This will give you enough clearance to swivel the light around 180 degrees and point it towards the interior of the truck. Also, before you drill your hole assemble the light with its mounting hardware so you can dry fit it and be sure to put the hole in the best position. The prototype in the photograph has its hole a little too centered to allow a full 360 degree range.
    As you can see from the photograph below the bracket fits over the lip of the door just like the top clip of the Out-Back antenna mount. Instead of one screw there are two as these are the only attachment points for the light. Attaching it was a matter of pilot drilling two holes for the stainless steel sheet metal screws and screwing it in place next to the power line egress point in the frame of the door. (An alternative suggested was to use a riv-nut - good luck!) A piece of foam gasket material was used to snug the door and mount together and protect the door from unnecessary contact and wear. Because the lamp base & bolt is isolated from ground by the two nylon washers you must secure the ground wire to the screw as shown. Inside the lamp I attached push-on spade connectors to the wires for easy tool free lamp replacement. Don't forget to allow yourself enough ground wire slack.
    To install the power wire I fished a long piece of stiff wire through the hole in the top of the door down through the hinge side frame into the door cavity. I then taped the 14 AGW on the end with duck tape and pulled a 20 foot length through the door to the bottom where I fed it into the truck along the same route I just used installing the coax. Finally, the power wire is protected with a small rubber grommet which also serves to seal out water. The wire is long enough to go to the engine compartment where the light is powered directly off the battery through a fuse and switched relay mounted on the engine firewall. The light switch is dash mounted in one of the blank positions near the radio
    I happen to like the TASCO light unit pictured here. It's inexpensive and can be bought where auto parts and farm equipment is sold. I've also seen variations at truck stops for under $25.00. It is a rugged 35 watt farm tractor work light in a shock-proof rubber housing that has the additional advantage of not marring the paint if it comes in contact with the door. They last for years on farm equipment and 18 wheelers. If the bulb ever needs replacing it can be removed and reinstalled by hand. I replaced the really bad Chinese made nuts and bolts that came with the light unit mounting bracket with SAE carriage bolts and modified the mounting by including nylon washers between the bracket and lamp base.
    You can see how the washer and nut arrangement provide smooth secure motion when I need to adjust the direction of the lamp. The second washer is out of sight between the platform and the lamp mount. Nylock nuts are the best I've found for shake resistant security.
    There are two types of people in this world, good and bad. The good sleep better, but the bad seem to enjoy the waking hours
    Pilbara WA
    Just thought I would revive this one, just because I think it is a great idea.
    Upwey, VIC
    I saw that on Discoweb's site, thought about doing it myself... but like most things i didn't get around to it !!!
    Pilbara WA
    It is from Disco web, I thought I had put that on it but must have missed it.
    Sorry to any doscowebbers who happen to pop in here.
    Jul 2003
    I saw it there too.
    I have a plug in magnetic based hand held light that does this job very well.
    (The disco roof is steel)
    Personally I wouldn't go to the trouble as clever as it is. As an emergency back up light as well it has merit.
    You will note that when the door is opened the light will travel with it.
    I unpack with the rear door open and light the rear not the side. The plug in gives me flexibility.
    Mahn England
    Ex 300Tdi Disco:
    Upwey, VIC
    What brand of magnetic light did you use ? Does it drain the battery much ?
    Queensland
    Hi Matbor, I have a 55w magnetic mount work/spot light. It comes with a small wireless remote control that turns the light on and off and has an up and down, and left and right control. The remote works up to 100 meters away.
    It’s called a Prolight. One of my customers had a 24 hour emergency Auto Elecs service and used one of these lights on his van so I got him to get me one.
    Heres a bit of rocket science for you. I got the light home, unpacked it, plugged the lead into the lighter socket and put the light on the bonnet and then realised that it would not stick. I tested it any way and then put the light away. It wasn’t until I sold the Discos that I found out that the roof was metal, quick hey. ops:
    Jul 2003
    All the details were on the box and the box has gone. I can only remember that it was made in China :roll: :wink:
    It was purchased from Binnings when they had auto stuff. I'm sure that Supercheep carry lines similar.
    20 minutes of use whilst setting up had no apparent effect on the battery.
    Drivesafe's lead is worth following.
    Hey Drivesafe I bought some magnetic L plates for the lads and didn't I look silly finding somewhere to put them on the LR. ops:
    Mahn England
    Ex 300Tdi Disco:
    ok i know this is a very old topic but was after some opinions
    looking at the way this mount is done to fit over the top of the
    discovery door i am wondering what ppl's opinions are on useing this
    type of setup for a reversing camera setup would it make the camera
    sit to high removing visability or would this be a good idea am thinking it
    would be a good setup and allow good height away from water and mud
    (unless things went real bad ) but lets not think about that other
    question i have is can this mount be brought by itself or would making one be a better way ??? look forward to any replys thanks guys
    worraps
