Results 1 to 10 of 21
Thread: Sand
    Pilbara WA
    Sand
    The fundamental theme with sand driving is to conserve your momentum. Since traction is at a premium, any increase in speed can be difficult, if not impossible, and you do not want to lose any momentum, as you may not be able to regain it.
    Tire Pressures
    The first thing to do before driving on sand is to lower your tire pressures. This is done to provide better flotation by increasing the size of your "footprint" and thus dramatically improving your traction. It also reduces the amount of strain on your vehicle and minimizes wear and tear on the tracks.
    The optimum tire pressure depends on your vehicle, the type of tires fitted and the terrain. The following technique provides a good starting point to find the optimum pressure and is best performed before leaving the bitumen.
    Park your loaded vehicle on a level surface and place a brick 1 cm away from the sidewall of your rear tire. Deflate that tire until the sidewall just touches the brick and then measure the tire pressure. Use this pressure as your starting point when initially lowering your tire pressure for sand driving. As you become more familiar with sand driving, you con alter this pressure as the terrain dictates.
    If you haven't performed the above technique before you reach the sand, don't fret. A good rule of thumb is to use a pressure of 15 psi or there about's.
    Remember though, if you are going to lower your tire pressures, ensure you have a pressure gauge and some means of pumping your tires back up.
    As you lower tire pressure, the tire becomes more vulnerable to damage by stoking the sidewall or rolling the tire off the rim. The lower the pressure, the higher the risk. However the gain in traction can be remarkable and may make the difference between becoming hopelessly bogged or simply driving away. The "correct" tire pressure becomes a decision between better traction versus increased risk of tire damage.
    In severe cases of bogging, tire pressure can be lowered to a minimum of 40 kPa (6psi), as most tires require at least 6psi to remain seated on the rim while stationary. In almost all situations 10psi should be used as the minimum pressure as 6psi is likely to result in tire damage ie. tires rolled off rims or punctured sidewalls. Speeds should be severely restricted at these low pressures. To minimize tire damage, it is important that these low pressures are only used on sand and tire pressures should be increased if limestone or rocky outcrops are encountered, or when the terrain becomes more firm. Failure to do so will almost certainly result in tire or rim damage.
    Sand Driving Techniques
    When traveling on sand, you should endeavor to follow in the tire tracks of the vehicle in front as they have already compressed the sand to form a firmer surface than un-traversed ground. Never drive on vegetation as this will destroy it and lead to erosion and environmental damage.
    You should avoid rapid changes in speed when accelerating or braking. Braking on sand will cause a mound to build up in front of all wheels and possibly prevent your vehicle from taking off. Rapid acceleration simply digs the wheels in and can actually lead to slower take-off speeds.
    Take-off should be performed as smoothly as possible with gear changes done at fairly high revs. Sand driving requires plenty of engine power to get your vehicle "planing" on the sand. It is advisable to use low range as this multiplies the amount of engine torque available and will provide that extra gear if you encounter a particularly soft patch of sand. Check that your tires are pointing straight ahead when taking off to reduce the takeoff effort required.
    When stopping on sand, depress the clutch and allow the vehicle to coast to a stop. This will minimize any sand build-up in front of the wheels. If the terrain permits, coast to a stop, rather than braking, with the vehicle pointing downhill as this will aid take-off. Avoid the soft sand at the base of most dunes and gullies when stopping.
    When turning, make the turn as wide as possible to reduce the chance of bogging. Your front wheels act more like a rudder in sand and turning too sharp has a similar effect to applying the brakes.
    Steep sand dunes can be traversed only straight up or down. If you drive even on a slight angle, the weight transfer is to the downhill side wheels. If the vehicle starts to slip, the downhill wheels tend to dig in and make the angle of the dune even worse, leading to a potential rollover.
    If you are traveling straight down a steep dune and the back end starts to slip sideways, it is best to accelerate slightly to try and straighten the vehicle. Never use the brake, as this will cause weight transfer to the front wheels and can increase the back end movement.
    If traveling up a dune and you do not get to the top, reverse down the dune in gear, NEVER coast down the dune and NEVER attempt a U turn.
    When you return home after a beach trip, it is important to hose down your vehicle to remove all traces of sand and salt. Pay special attention to areas like the mudguards where sand is sprayed around and tends to get trapped. Thoroughly hose underneath your vehicle as well, as there are many nooks and crannies where sand con also get trapped.
    Vehicle Recovery in Sand
    As soon as you become bogged, avoid the temptation to simply floor the accelerator as this will just make vehicle recovery more difficult. Put the vehicle in reverse and gently try to back along your tracks as they provide a compacted path. When you have reversed a sufficient distance, try going forward again while being careful not dig yourself in. Hopefully you will travel further each time you repeat this technique and eventually be able to slowly pass through a particularly soft section.
    If you cannot reverse out of trouble, get out of the vehicle and let your tires down further. A rule of thumb is to drop them by a further 12 psi. Before trying to reverse out, remove the build-up of sand from behind the tires. See if any part of the underside is touching. If it is, clear the sand away to allow the vehicle to reverse out. You may need to try this several times.
    If necessary, continue to drop the tire pressures to 10 psi. Also, never underestimate the assistance of your passengers giving a push. As mentioned earlier, tires can be lowered to 6psi in extreme cases, but this should be avoided if other means of vehicle recovery are available.
    If you are still stuck and your tires are down to the minimum pressure, you will have to resort to a snatch strap, winching or jacking to extricate yourself. The easiest method is usually by snatch strap, but this relies on another vehicle being present. If you are by yourself you will have to resort to winching (if you have one!) or jacking.
    Summary-Sand Driving
    lower tire pressures to greatly improve traction and reduce track erosion
    drive smoothly with gear changes at high revs
    ensure wheels are pointing straight ahead when taking off
    avoid the soft sand at the base of dunes and gullies
    make turns as wide as possible
    ONLY travel straight up or down dunes
    follow in others tire tracks to drive on compressed ground
    avoid braking by coasting to a stop
    do not floor the accelerator if you are bogging down
    when bogged, try to reverse on your own tracks
    thoroughly hose down your vehicle after a beach trip
    There are two types of people in this world, good and bad. The good sleep better, but the bad seem to enjoy the waking hours
    Bracken Ridge, Qld
    BB I hadn't seen this thread before.
    Some great tips. I had read these in various places but rarely as concisely and clearly put together as you have done.
    Nice job. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Pilbara WA
    You have been trawling back to some of the first posts I did.
    August last year this one.
    nige Guest
    Bogged
    Excellent info. for uninitiated beach drivers. (and some supposed experienced ones also).
    Saw a fully laden Tojo towing a fully laden trailer on my local beach,
    up in the soft sand instead of lower down, hit the brakes hard when
    he realised he'd just driven straight past the track. He was lucky he
    could still open his doors!
    May 2003
    On The Road
    The balder the tyre the better on sand too,,
    though the trip to the beach becomes increasingly difficult :wink:
    Pilbara WA
    Now there is a can of worms. 8O
    I have seen this comment on other forums break out into total WAR as people argue for their veiws.
    Some will say Bald is best, while others will say you need a good mud tyre to work well.
    Both seem to agree that low presure is still needed.
    So good luck Pedro, you opened this can :wink:
    May 2003
    where ever I fall asleep ,Queensland
    :roll: was gunna add my two bobs worth into this one ,but thought against it and decided to leave it in the bank and live off the interest [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    Pilbara WA
    Originally posted by fernockulated
    :roll: was gunna add my two cents worth into this one ,but thought against it and decided to leave it in the bank and live off the interest [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    But if you round it down as you have to now you will end up with 0 cents.
    hmmmm seems fitting I think :wink:
    May 2003
    [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] sorry ,all your talking reminded me about the price of <span style="font-size:12pt;line-height:100%">inflation</span>
    Western Australia
    Re: Sand
    Well done BB [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    It's amazing how many times I've seen drivers who obviously don't know any better drive up a steep dune and drive a "U" shape 8O 8O
    As far as tyres personally I prefer A/T treads for the sand, my experience is that agressive treads dig in too easily, although I've never had "baldies" to try out.
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
