Results 1 to 2 of 2
Thread: tyre load rating
    Aug 2010
    Clare Valley
    Question tyre load rating
    Hello guys
    Not trying to start a debate on steel or split rims but
    could use some advice or confirmation....i get totally lost when i start reading about tyres and aspect ratios.....but even more confused when trying to figure out the load rating or bias ply rating.
    According to a couple of sites the maximum axle weight for the rear of a 110 is 1850kg (1850 +1200 at the front which = Gross Vehicle Weight of 3050KG).
    1. So taking the heaviest axle weights..... each tyre at the rear needs to be able to handle the load of 925kg.......RIGHT?
    2. Therefor, looking at the specs for the "Super Traction" tyre http://www.mrftyres.com/downloads/lighttrucks.pdf any of the tyres would be ok? (though the last 2 tyres would be a closest match to a 806mm OD(7.5R16))........am i right???
    Darryl
    JDNSW's Avatar
    Yes. It is unlikely that you will find a light truck tyre that will fit on the rim and is rated for a lower load than the maximum on a 110 (130 you might or a passenger tyre).
