Results 1 to 3 of 3
Thread: Snr Commanders
    Sep 2013
    Snr Commanders
    Does anyone know if the Perentie Snr Commanders have a separate battery circuit for the radio distribution box or does it just run off the cranking battery ? Also is it possible to remove the aerial mounts off the side or are they welded on ?
    Feb 2005
    pretty sure the radios run off 24V therefore pretty there is a 24V generator and a seperator circuit
    i would assume the mounts are bolt on
    Davehoos Guest
    24v SYSTEM IS COMPLETELY SEPORATE.it used 2 batteries in the rear box..
    arial brackets bolt on-top bolt might be under pannel join so it may require lifting up the window panel.
