Results 1 to 10 of 17
Thread: Handbrake for iMac not working
    Jun 2008
    Suburban Canberra
    I installed the latest update for Handbrake and now it will not copy any DVDs.
    Any hot tips on other applications I can download to copy DVDs or how to fix Handbrake?
    I'm not looking for illegal download sites, I just want to copy the DVDs I've bought before the ankle bitters scratch them.
    Feb 2011
    Brunswick, Victoria
    It's a bit long winded but you can use MakeMKV to rip the dvd then Handbrake to convert to something iTunes friendly, or just play back the MKV with VLC.
    St Helena,Melbourne
    4.28 MB
    I also found that it wont copy discs on windows which i believe has to do with anti piracy security now built in .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Usually this happens when they put in a new anti feature. Best bet is to either find another one that works, wait for the update or keep an archive of all the versions and go back until one (usually very early) works.
    Jun 2008
    Suburban Canberra
    Quote Originally Posted by clubagreenie View Post
    When you install the latest version of Handbrake it tells you that it does not agree with removing copy write protection. The old versions worked well.
    So, how do I install an older version of Handbrake from my Time machine back up? I've been able to install older versions of documents but when I try Apps it looks like I'm about to back date my entire hard drive
    You need to remove the current version and put the .dmg (or similar) files onto the machine and run install again.
    Jun 2008
    Suburban Canberra
    How do I get the old .dmg file from Time Machine?
    OK I worked that bit out. For those who do not know you highlight the App you want to replace, open Time Machine and step back until you get to the version you want and then press Restore. Time Machine will then ask if you want to over-write the new app with the old one.
    This still did not help as I got a message saying that the restored version of Handbrake was not compatible with 64bit-something.
    Jun 2008
    Suburban Canberra
    This is getting out of hand.
    I put the old Handbrake back on the iMac only to find it is 32bit and will not work with the 64bit VLC.
    So I'm still on the hunt for a good ripper.
    Jun 2010
    Merrijig Vic.
    try this link
    Top Three Free DVD Ripper for Mac - Rip DVD Free on Mac OS X
    Maybe one of the ones mentioned will work for you.
    Tony
    Jun 2008
    Suburban Canberra
    Well I tried MacX DVD ripper Free.
    It seems quick and easy.
    Works with the DVDs I've bought, including a region 4 DVD no problems (just ignore the request to change zones and start MacX DVD ripper).
    It did not rip my Ivor the Engine DVD - Nothing has ever been able to rip my Ivor the Engine DVD. It is a region 4 DVD that I got for my kids when I was in the UK. I remember it and want them to see it.
    It is a 30yr old kids program and nothing can rip it. :\
