13th October 2013, 10:32 AM
intercoolers on td5 extremes
Hey everyone i just got a quick question. A bloke i meet told me that td5 extreme defenders already have a bigger inter-cooler on the front and that's why the nose sticks out a little further.
Is this correct or was he telling me porkies.
13th October 2013, 10:57 AM
You'll probably find it has the extension for air conditioning, different intercooler..... don't think so.
13th October 2013, 12:51 PM
13th October 2013, 01:05 PM
#4
Just replaced my inter cooler on my 2002 td5 defa and no they haven't made a bigger inter cooler as stock standard so your mate may have been misinformed
13th October 2013, 01:16 PM
#5
13th October 2013, 01:19 PM
#6
Hans is urs an extreme cause its close to the year of mine. i just wanna know cause towing my camper my car gets really hot and loses performance so i thought a bigger intercooler would help.
13th October 2013, 01:25 PM
#7
This isn't correct they have the standard intercoolers
Put an Allisport Intercooler in to overcome your issues
If the coolant temp is high put an Allisport alloy radiator in as well
13th October 2013, 03:04 PM
#8
Yes it is a extreme 2002 td5
Haven't had a issue with over heating
As in previous reply more likely radiator problem if overheating
Replaced inter cooler for better performance
Only finished yesterday so we will see
14th October 2013, 10:31 PM
#9
Hi Flaps,
It will be the standard one, mine is a 2001 TD5 Extreme came with the standard I/C. If you want one at a reasonable cost try TRS in Adelaide that's where I got mine from. Other than that go with the Allisport one as recommended. If you replace the intercooler consider changing the hoses as well, well worth while whilst you have things in bits. I went silicon, seem to work fine.
14th October 2013, 10:55 PM
#10
I changed the intercooler in my 1999 td5 defender for one out of a D2a
which is about 30% thicker.
