Thread: Why does my air con take so long to get cold?
    Mar 2010
    Before I take my vehicle in to a air con place, and it starts costing money, I thought I would quiz some other D2 owners.
    My climate control seems to take a ages to start pushing out cold air.
    In the Auto mode, some days the only way I can get cold air is by taking the temp setting all the way up to high and then back down to the temp I want. This almost always gets me cold air immediately. Once it starts getting cold it then works fine.
    I have checked the system and there are no fault codes.
    I have removed and cleaned the temp sensor behind the driver side grill and the little fan is spinning.
    I don't know when last the system was serviced, if ever.
    Is it usual to replace the receiver driers on these systems?
    I have been bitten before by a supposedly reputable air con / radiator company and want to at least have some knowledge before I walk in.
    Ryan
    Oct 2010
    Milperra NSW
    Try checking and cleaning the condenser for derbies and road grime.
    With the A/C on MAX, feel the low pressure pipe coming out of the compressor. It should be really cold, even forming some condensation on it.
    With the A/C on MAX, is the compressor staying engaged? Or is it cycling on and off ?
    Have a good look around under the bonnet at all the A/C fittings, pipes and hoses. If there is signs of a oily residue which usually will have dirt and dust attracted to it, you may have a leak.
    I just had mine serviced, evacuate and re charge with new gas, oil and new receiver dryer. It hadn't been touched in 10 years and was down on gas, so I thought it was a good time to get it back up to spec ready for summer.
    Hope that might help.
    Craig
    Mar 2010
    Thanks I will have a poke around later.
    What did the service and receiver drier cost?
    Ryan
    Oct 2010
    Milperra NSW
    Because I had the dual A/C system (front & rear) it holds more gas, so costs more than a single system. I had a mobile guy come out, cost $400 the lot. The receiver dryer isn't expensive, it's the gas that's costs the $$$.
    Craig
    Mar 2010
    I thought I would close this off in case anyone else has similar problems.
    The aircon guy tested the pressure and there was 100 psi at 25 degrees C which he said was sufficient.
    Long story short after swoping and testing a few sensors I had found nothing wrong and was preparing myself for a big bill at the auto electrician with visions of having to pull the dash apart.
    Anyway as a last resort I checked the fuses and relays. In the engine bay fuse box I swopped the aircon and hooter relay as they are the same. Immediately I had instant cold air and no hooter. At this point I felt like I had won the lottery.
    So popped the faulty relay open and found a lot of black ash.
    So new relay and all is good with the world.
    Oct 2010
    Milperra NSW
    You have just reminded me! When the guy serviced mine he swapped the A/C relay for the horn. They were still working his thinking was the A/C does a lot more work than the horn so we will share the wear around...
    Craig
    Bracken Ridge, Qld
    - because it's in a Land Rover......
    On the upside, and against all logic, and just to make you feel better... the air con in my new(old) Tdi Defender works REALLY well !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
