Thread: 2L core plugs - confused!!
    ashhhhh Guest
    Hey all,
    I have to replace the threaded core plug which sits at the front of the motor, and is partially covered by the manifold.
    Is it, or is it not 1" BsCon on the 2L engine('55 in my case)?
    I have read info which says it is, others seem to have no idea..
    I don't have easy access to thread gauges etc and don't really want to start buying random items without being sure.
    Ash
    JDNSW's Avatar
    This was discussed here at length several years ago. I can't remember the answer, but a search should be able to find it. I seem to remember it is a very unusual thread!
    ashhhhh Guest
    Yeah I've searched a lot and find conflicting info.
    Bugger it, I managed to locate and purchase a 1" BSCon tap today - I'll see how it goes! (And confirm if it's right)
    Feb 2010
    Core plug
    I put my finger thru one whilst cleaning the engine before a weekend trip...
    I had a plug out of a TD5 and it went straight in.
    Go figure.
    So I bought 3 more.
    Worth a try. Let us know if it works.
    Irymple, Victoria, Australia
    It should be a "BS Electrical Conduit Thread" and have 16 threads per inch (TPI) for that diameter. If you clean the thread out you should be able to check it by using a 3/8 Whitworth bolt as a thread gauge, as it is also 16 TPI.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    thread
    Hi all
    have to say it all over again
    the thread is British standard pipe
    I have a quantity of plugs
    let me know what the out-side diameter of the thread as I have two different ones, believe one is 1600 other 2lt.
    let me know what you wish to pay as I bought them years ago and forgotten what they cost
    Ian
    Jan 2008
    Brisvegas
    IIRC Incisor sells them in the "Dave's interesting Things" shop. He had them made up by a machine shop.
    CC
    edit: Yep
    http://www.davesitshop.com/davesitsh...ewCat&catId=33
