What do you want to know You can get this from joining a lroc in your state.
There are several manf of after market tanks for land rover defenders or 110 defenders but you can go severall ways the most popular that i do not like is the 130 plus rear after market tank and i do not like it because it put a extra 55 kg to the rear of the diff and reduces the load carring of the vehicle it could tipp or raise the front wheels because of the leaverage of the 55 kg when it is out 3 ft or 900 mm from the diff i like sill tanks whih fit under the vehicle between and add a further 100 ltr tpo the cap of the vehicle wht you do is have a locl mnf measure the tanks for you and then fitt them and have them plumbed and filled from the same filler as the reguler filler
