I've got the Rest of World checklist for D3 but can only find the EU checklist for D4.
Here:
http://media.disco3.co.uk/gallery/al...rom%20MY10.pdf
 Swaggie
						Swaggie
						I thought I had a copy of the D4 maintenance schedules but perhaps I'm thinking of the D2 ones that I had. Does anyone have the D4 maintenance schedules (normal and arduous) and checklist they could share?
 Master
						Master
Here:
 Swaggie
						Swaggie
						The UK/EU version is a good start - thanks.
PS. Taking an hour to change the fuel filter seemed excessive although that included having to re-tighten the water sensor after the drain tube got moved enough to leak.
Hi,
I've down loaded these from the LR TOPIX Owners Website using my VIN.
They are for a 2.7 MY11 TDV6.
I understand they are different in Kms between services by a few thousand kms between the 2.7 and 3.0 engines.
Looking at the Arduous Service Scheduling gives a great snap shot into a "Preventive Maintenance" servicing for those of use that use the vehicles for touring and off road.
 Swaggie
						Swaggie
						I'm changing engine oil at 15K intervals so minor differences between the 2.7 & 3.0 are inconsequential. I'm not sure that I'll leave the accessory belt go for 240K due to often dusty conditions but probably no need to change it at 120K that I was about to do, especially considering that the gearbox is mostly in top gear.
 Wizard
						Supporter
						Wizard
						SupporterLots of mention of the electric handbrake, including servicing it every 80km when used off road. Perhaps if we all followed these recommendations we wouldn't have so many failures. However, it may be difficult to get to the motor on cars with a long range tank since mine had to be removed to replace the handbrake motor.
I will have to learn how to clean and adjust mine to prevent future problems since I do lots of off road or rough road driving.
Bob
 Fossicker
						Fossicker
						Just for clarity, if you check the LR4_MAINTENANCE_SCHEDULES_156749.pdf in AGRO's post
you will see that Australia is on the UK+EU Schedule, not R.O.W.
Australia 24000 km / 12 months 26000 km / 12 months Yes EUR - JLR 14 71 **_*E
DISCOVERY 4 / LR4
Market - Australia
Interval Except 3.0 - 24000 km / 12 months
Interval TDV6 3.0 TDV6 - 26000 km / 12 months
SAI Light Enabled - Yes
Check Sheet - EUR - JLR 14 71 **_*E
