yesterday i decided to fill the main gear box and the transfer box with oil as i waited for the prop shafts to dry. Tonight as i fitted the front prop shaft i got a drop of oil on my glasses, this resulted in a colourful word
i have attached a photo of the suspect oil leak spot, my questions are:
1: is the flange the prop is connected to the out put shaft flange/
2: what seal do you think i need to replace?
Yes, it's the output shaft flange. Any bearing shop should be able to supply you with a seal .The number is P 3014. The old Land rover part no. is 236417. The measurements are 1.625 x 2.500 x 0.375. .W.
