Results 1 to 4 of 4
Thread: Flasher unit
    Lesmurdie - Perth WA
    Flasher unit
    Does anyone know where the indicator flasher unit is located and what it looks like. It's a 1999 defender 130 TD5
    Oct 2008
    Behind the instrument cluster.
    They often fail due to a dry solder joint. Very easy and cheap fix if you have a soldering iron.
    Flasher
    Quote Originally Posted by BilboBoggles View Post
    Do you know what it looks like? Found two components behind the cluster, neither is identified as the flasher unit.
    Flasher unit
    Found the flasher unit. Is located in the fuse/relay box just forward of the gear stick .
