25th October 2013, 09:15 PM
New Disco Issues!
Hi Guys,
Today I picked up a 1999 Discovery V8 ES model and now going over the issues to fix. Any help appreciated!
1) I have figured out that only the driver's door locks and unlocks with the remote. The driver rear door unlocks, but is tough to open. Both doors on the passenger side need to be opened from the inside. All doors lock with the remote.
I've tried to read what I can on this. Is it likely the actuator on all three but the driver's door have gone? Would anything else be worth trying such as spraying WD40 in the latches or otherwise?
If I do need new actuators, are there any recommended places to buy them, and would diesel models fit my V8 model? It looks like a pita to change them myself, would it be worth the labour costs?
2) The last owner changed the water pump recently and added a new fanbelt at the same time. It makes a whining noise when driving now and his mechanic mentioned that the fan belt needs to be run in. I imagine the adjustment must be off, or the belt is the wrong size?
3) I have the three amigos to top it off, but will see a mechanic on Monday and try get the codes looked at - when I also get him to check the fan belt.
Please help with the locks in particular!
Thanks,
Antony.
25th October 2013, 09:22 PM
Re the door locks.....it's not set to single point locking is it?
That's where you need to push the unlock button a 2nd to unlock the rest of the doors (for safety/carjacking reasons).
25th October 2013, 09:28 PM
Thanks for getting back to me. I pressed the button twice to no avail. It might have had an effect on the driver side rear door, but not the others. I also made sure the child locks weren't set.
I just saw an old thread that recommended Jaycar for new actuators if they are indeed the problem: Slave Door Lock Actuator - Jaycar Electronics. Would these be correct?
25th October 2013, 11:40 PM
#4
Door lock assys
If your doors are locking ok but not fully unlocking buttons pop up but not enough to open door from outside but if you pull button up from inside they open its a sign you need new door latch assemblies.
Front door RH RHD / Central Locking Motor Assembly
P/N FQJ102880
Google above and look for fitting instructions.
Done three on my D2 in last six month OSF NSR and tailgate
Best to use genuine new assys not cheap so shop around about £75 each in UK
Warning lights google (three amigos option
Hope this helps Pete
26th October 2013, 09:06 AM
#5
Thanks for the tip. From what I can see the door buttons aren't moving at all when I go to unlock them. I can hear the mechanism in the door, but they aren't popping up at all. They pop up no problem when I unlock them from the inside.
I just had another look, and both the back doors are a little tough to open when I have them unlocked. Basically when I pull the handle the latch isn't springing back so not sure if I also need a new spring or something for those, or whether WD40 would fix the problem.
I imagine I need two actuators for the passenger side doors though.
If possible, please get back to me with thoughts asap as I want to head out and try and find all necessary parts to fix the issue today.
26th October 2013, 09:52 AM
#6
Hi Discotrip, with your doors which are difficult to open from the outside when they are unlocked. I had this on my passenger door, fixed it by adjusting the door handle to latch control rod. The control rod has a plastic clip screwed onto it which clips to the door latch, unclip from the door latch then screw the plastic clip out a few turns. This means that when the exterior handle is pulled the control rod is pushing the latch release down a little further, if that makes sense.
Free fix if it works for you
Bernie
D2 TD5 Manual
26th October 2013, 10:42 AM
#7
Great, thanks for that. I'll have a look when I take off the panel.
26th October 2013, 10:45 AM
#8
Also, will the Jaycar acutators be good enough or can you guys recommend another place to buy them?
26th October 2013, 11:46 AM
#9
RH Front Door Lock with Actuator Land Rover Discovery 2 FQJ102880 - All Four X 4 Spares
As above
You cant fit universal door actuators on a discovery 2.
Try removing the locks and blowing out with air and contact cleaner, sometimes works.
26th October 2013, 05:08 PM
#10
Thanks, I've just ordered the actuator for the front passenger door from there, and a second hand one for the rear which I found on eBay. Will see if I can fix all the doors next week.
Taking it to a mechanic to get the fault codes for the three Amigos on Monday. Also, the whining/whirring noise sounds like it's coming from the alternator or something, perhaps a bearing or other issue?
Antony.
