Greg
Not for sure, but it sounds like your EGR valves could be sticking ? There are some similar threads on the Ffrr forum which might be worth a read.
Laurie
Hi guys, I've had my 2012 TDV8 for a couple of months now and I've just started noticing a distinct - and infrequent - large fall-off in power every so often. It seems to happen quite without warning. Suddenly, as I accelerate out of an intersection or a corner for example, the revs will tank to below 1,000, just a sudden and immediate loss of power. Then I'll tickle the throttle a bit, , the gearbox will figure itself out, and it'll pick up again and everything will be normal.
It happened just this afternoon, I was towing the boat back from the ramp. But it doesn't seem to be dependent on being under larger-than-normal load, it seems to happen completely randomly.
Has anybody else experienced anything like it?
Greg
Laurie
Greg
Exhaust Gas Recirculation
If you could remove these your power goes up, BUT your fuel consumption goes down. They are fitted for emission control.
Laurie
Sent from my C6603 using AULRO mobile app
2010 TdV8 Autobiography, D2 Td5, RRC 4 Door VM/300Tdi, RRC 2 Door V8
Greg, sounds like the system is cutting power, it will be doing so because of an issue - suspected or real. There will be logged faults.
Or maybe throttle position sensor
Greg this is the link to the article I had read
fullfatrr.com - View topic - TDv8 drive stutter
Laurie
Okay, well I can't imagine it's an injector fault as described on the fullfat thread, since the car has only done 16,000km from new. But I've got it booked into Barbagallo service for some tests on Wednesday, so it'll be interesting to see what they come up with. Will report when I know more. Thanks for the input guys...:-)
In general, failing crank angle sensors tend to fail when they get hot. If you can get access to it, next time try spraying some cold water or drink onto it to see if the problems disappear for a few minutes.
