Results 1 to 10 of 12
Thread: Floor coverings for a Series 2
    Jan 2013
    melbourne
    I am rebuilding my 1961 SWB (Read rebuilding, NOT restoring). I have stripped, sanded, de-rusted and painted the interior; rewired it all, put all new rubber seals throughout (including the roof); etc, etc....
    What is the popular consensus with putting carpet on the floor? I have a good friend who is a carpet layer and he has given me some top quality marine carpet. Should I put that in or just get a removable rug?
    smurf village
    why would you put carpet in? would have it fixed to the firwall or just as floor mats or using existing holes
    Jan 2013
    melbourne
    Just a passing thought LS,
    smurf village
    but would it be for sound proofing, heat proofing, looks or comfort, cleaning or something else?
    we had it in the defender we owned and it looked quite nice
    JDNSW's Avatar
    I put rubber matting in mine.
    Dec 2009
    Queensland (though occasionally elsewhere)
    Rubber matting would be the go.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    10mm rubber over the top of 10mm foam exercise matting
    No heat and way less noise
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Dec 2008
    The Oaks
    Carpet could be OK, though the skirting angles especially up the firewall may be tricky.
    Narre Warren South
    Quote Originally Posted by reg of the overflow View Post
    Carpet in a Land Rover ?
    Range Rover & Disco yes but a Series.... ?
    I fitted rubber mats to my Series I and will probably do the same to the others when they get put back on the road. My Defender also has rubber mats. Easy to wash clean and don't soak up the water that leaks in.
    Checkerplate rubber matting from Clark Rubber cut to fit.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2012
    Porongurup Western Australia
    I'm definitely with everyone else on using rubber matting, I've got 10mm rubber matting in my IIA and it's also got a layer of soundproofing material over the gearbox and it definitely helps reduce the noise.
