Results 1 to 10 of 12
Thread: Lifts.
    Townsville
    Lifts.
    Does anyone know the original height of a D2 and where the inspectors would measure this from.
    I want to know this so as to choose what suspension and tires to get, and weather or not it is worth going bigger and get it engineered.
    Will
    Dec 2012
    Perth, WA
    Dont quoteme on this but I know it's on the RAV. Unfortunatly I'm at work with no RAV CD.
    I think is 480mm from wheel centre to the guard.
    Happy Days.
    Oct 2013
    Emerald
    Lift eh!
    So If I cut the guards and put flares on to accommodate my tires how would they be able to tell and does that mean it would be illegal?
    Dec 2012
    Perth, WA
    I was just giving details of what I think the original height is and how it's measured in the RAV.
    I haven't checked yet.
    Happy Days.
    May 2009
    Tatura, Vic
    Don't know if this helps but as I have just put a steel bar on the front I measured the height before I started, as I also have a 2 inch lift ready to go in.
    Mine is a Td5 with SLS. The height from the bottom of the wheel arch to the ground was 825 mm
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Dec 2012
    Perth, WA
    Quote Originally Posted by Mr Whippy View Post
    Ground height isn't much help to most of us mate because we have different tyre/wheel heights.
    Distance to the centre of the wheel wont change unless the guards are chopped.
    Happy Days.
    Townsville
    Thanks Joel.
    Mar 2010
    I think that engineers use the overall height of the vehicle measured from ground to roofline. These measurements are in the car manual, and possibly on the back of the sun visor?
    The height of your vehicle in regards to the law does not differentiate if it's from tyres or suspension in regards to the maximum height a vehicle can be raised.
    They look at tyres not based upon hub to guard measurements, but on the industry standard of tyre size measurements.
    I think you will find that your disco is probably somewhat lower than factory spec anyway, so you can raise quite a bit.
    Hope this helps
    Kev
    2005 TDV6HSE D3
    2006 V8HSE D3
    99 TD5 D2 (Gone)
    97 RR Autobiography original (Gone)
    Townsville
    That makes great sense. Hahah always the simple way isn't it. Cheers for that.
    Dec 2012
    Perth, WA
    So if you chop the roof like a hot rod, you can get away with a heigher lift.
    Happy Days.
