There is internal rot, you may have to replace the firewall in not too much time. One less severe option is to cut out the corner and fit some repair sections.
First action would be to cut out a small window around the hole to get back to good metal and weld back in a piece of sheet. The window will at least let you know how much of a problem is inside. (If you can borrow an endoscope even better)
Treat the inside with Penetrol Anti-Rust control before it gets any worst.
