Results 1 to 10 of 25
Thread: Q+A defender (what can go wrong)
    Jun 2013
    adelaide
    So this is a little more of an introduction about me and a few questions and comments.
    Firstly about me
    Im just a young kid (compared to others around the traps, im only 21) with ambitions. I work in the caravan and RV industry in Adelaide and am working on setting up a Camping and 4wd website for it (a lot of the suppliers are the same)
    Any questions about stuff id be happy to help out with.
    Anyway
    Are they breaking down as often as people say?
    Whats the big issues, what breaks or causes the breaks?
    what are my options if things go wrong (i was thinking ls1 if engine breaks)
    what can the Australian defenders tow? ( i could look this up but lazy)
    cheers for the answers guys
    Aug 2011
    Warburton WA
    Quote Originally Posted by pickstock View Post
    Anyway
    That depends on who you talk to. I bought mine new in 2011 and while I've had some warranty work done on it (without any problems from the dealer) it's never broken down. The car is nearly at the 100,000k mark now.
    Lack of maintenance. My understanding is that these cars need regular servicing etc I also think that how it is used would probably play a part in this as well.
    New car or 2nd hand?
    Mine is a short wheel base 90 and is rated at 3.5t and from memory a towball weight of 240kgs
    See my answers above.. I am sure that others will be along with more information for you soon.
    Nov 2011
    Firstly about me
    Anyway
    As above tends who you talk to, I have had a number of Land Rovers, Series 2a, 3, 110 and Defenders all have been second hand so once I fix the problems it had and maintain it properly then no. The Defender I bought at nearly 12 months old (2010 model) and the only major problem has been an intercooler hose that rubbed through and this can happen on any make.
    Same as above they need to be maintained properly. Depending on what you are looking at looking at the problems are different on on each model.
    It will depend on what type of engine it is and what breaks, I have fixed a V8 County with a piece of cardboard in the distributor.
    From the Defender Specs
    Unbraked Trailer 750kg
    Braked Trailer 3500kg
    Hope that helps.
    Richard
    Jun 2013
    adelaide
    sorry really should of been more specific
    Im looking for second hand around the 10 000 to 20 000 mark (big jump i know)
    im not sure what engine i want, probably a turbo diesel 200 or 300 TDI
    Ive done a bit of work on a Dakar car and that used standard land rover transfer case and drive shafts so i know they are good. Just a bit worried because talking with my mechanic he has pretty much said he wont touch them (probably will for services but not major work)
    thanks guys
    spike
    redrovertdi Guest
    thanks guys
    spike
    Both those engines are from the 1990s and i doubt very much you will find any thing with that mileage unless you add another zero. my Defender has 436000ks and lots get replaced as it wears out due to work and play. I love it...
    Jun 2011
    Berowra Heights NSW
    thanks guys
    spike
    This is the same old story with most mechanics, they all reckon they would not touch one if there life depended on it.
    Most of these mechanics I think are scared of them for whatever reason.
    I have a 2000 TD5 that is 5 cylinder turbo diesel, it is a great veichle, only had the starter motor (brushes) and the clutch master cylinder fail on me
    The Defender is a great solid veichle and will go where most veichles will not go.
    Parts are not thar dear and if you are slightly mechanical
    Minded you will be amazed at what you can do on a Defender.
    Also think of the Defender as a blank canvas, you can add and do whatever you want to do to it, where if you had a Toyo, etc you wold not .
    Hope this helps and welcome, it is good to get some young load into Defenders.
    Didge Guest
    Parts are cheap compared to Jap cars. If you spend $10k - $20K you'll probably get a reasonable TD5 which has a lot more get up and go than the TDi's. Funny that Jap car owners are asking things like "Is that old thing still going?" and the answer is yes, they're generally reliable; won't let you down with a show stopper mechanical problem any more than your jap cars. My old 300TDi has manual everything. If I drop the key in the water, it still works. if my hands and arms work, so do the windows and door locks. There are no electrics or electronics, computer, etc to let you down, not that they do that very often anyway. The problem with electronics for the average punter is diagnosing the cause of the problem. All diesels require regular maintenance but the 200 & 300TDi can tolerate poor quality fuel more so than modern diesels. My 300 has had no major issues in 245000kms and it has only been the bolt on ancillary items under the bonnet that have worn out prematurely. eg clutch master cylinders seem to leak prematurely, as do standard rear axles and drive flanges but all are easily fixed at a reasonable cost. I 2nd all of greyfox's comments.
    Get one and you'll join an exclusive club where every time you get in it , you'll get a special feeling and you'll be on the look out for others to wave to. That doesn't happen in a Toyota or Nissan. Wish I'd got one when I was your age, you won't regret it
    JDNSW's Avatar
    As the others have said. Most mechanics are frightened of them, because, being relatively rare, they are unfamiliar, and not worth the effort of learning because they may not see another one for twelve months.
    The dealer network is not good outside the major cities, and even there many of the dealers are not interested in older examples. In my experience, dealers are not a good or cheap source of parts, but in general parts for all except very old models are readily available and cheap from a number of non-dealer suppliers.
    My 110 is approaching 600,000km and the only show stoppers have been an alternator failure and a problem with the starter solenoid (both Nippon-Denso on this model), and a broken gearlever, so I doubt that it can be called unreliable. On the road within hours in all three occasions. Just drove on a 2000km round trip to Brisbane and back with no worries or problems.
    Didge Guest
    Wow, that's a serious amount of clicks for any motor but it's the isuzu isn't it?!
    Jun 2013
    adelaide
    yeah i was talking about how much i was hoping to pay
    ive read all the books and am very interested its just the fact its a lot of money to spend for me at the moment, this would be my first reasonably expensive car as well.
    I sort of am mechanically minded but barely have the time to do it so will probably palm it off.
    i was under the impression the td5 was less powerful than the tdi200
    Im thinking when i get one ill do some basic mods, like the bar work and mild lift kit, ATW intercooler. Stuff more for protection of the equipment than for outright power.
