Results 1 to 3 of 3
Thread: Two quick questions - fan hub and EFI V8
    Jul 2007
    Two Rocks, W.A.
    Hi all
    To quick questions on the County…
    1. My new fan hub arrived yesterday, can this job be done safely/easily without a hub spanner? From what I can see the fan shroud should lift out of the way and give reasonable access…
    2. I have the chance to buy an EFI V8 (still only a 3.5) from an '89 RRC. What will I need to consider or will this be a straight slot in? I'm thinking the air box may be an issue, but I don't really know what the RRC's have…
    Mike
    '00 D2 Td5 'Alice'
    '03 V6 Freelander 'Phoebe'
    '04 Td4 Freelander 'Harry'
    Landy86 Guest
    There's a bit involved
    I have a efi 3.9l in a 110
    Different fuel pump
    Regulator
    Lots of wiring
    Ect
    And I'm pretty sure I have hub spanner in car
    I live just near quinns if ya wanted to borrow it some time?
    Jul 2007
    Two Rocks, W.A.
    Quote Originally Posted by Landy86 View Post
    Different fuel pump
    Regulator
    Lots of wiring
    Ect
    Thanks mate! I'll shoot you a PM a bit later…
    Damn - I'd hoped it might be all pretty self contained, ECU etc. I know from previous (3.9 & 4.0) Disco's they have the in-tank pump, I was sort of hoping an '89 RR might have been external.
    I wondered what it was behind the shield under the County when I got it - I was running on LPG so the pump wasn't making any noise
    Mike
    '00 D2 Td5 'Alice'
