Results 1 to 8 of 8
Thread: Turning circle
    Aug 2012
    Tewantin (NOOSA area)
    Turning circle
    Old question
    How many turns in on the Defender steering stops can I go in to reduce turning circle?
    RF
    Did 3 turns on a MY12 Puma D90, no rubbing on stock MTRs
    VladTepes's Avatar
    Bracken Ridge, Qld
    Land Rover Defender - turning circles.
    90: Disproportionately large.
    110: Onerous.
    130: Ridiculous.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Oct 2007
    Wantabadgery, N.S.W.
    Does alteration of the stops to improve TC cause accelerated wear of the steering components?
    Sep 2006
    Northern Beaches
    I fitted -25 offset rims and it made the turning circle smaller without adjusting the steering stops. I don't use them all the time but it is noticeable.
    Jeff
    Quote Originally Posted by Don 130 View Post
    Probably not that you would notice.
    Apart from larger tyres rubbing the trailing arms, if all else was OK the cv's are the limiting consideration on how far the hubs can be turned. The balls get too close to the weak zone near the edge of the inner "star" or outer "bell".
    Even when the stops are not adjusted for more lock you need to be careful on the accelerator reversing uphill on full lock. With a load it is prudent not to use full lock when reversing up hill.
    Oct 2007
    Thanks John, I'd love some more lock (I've got the standard 130 rims) but don't want to pay with worn out bits. Any Idea how much I can safely go?
    Don.
    I don't know what wheels and tyres you have.
    Lift the axle onto stands so the tyres are just clear of the ground.
    While the steering is turned to full lock one way (i.e. against the stops), spin the wheel and it should be completely smooth with no feeling of vibration or roughness coming from the cv joint.
    Turn to the opposite lock and repeat.
    You are getting the feel for what is normal.
    Adjust the stops and turn the steering to full lock and repeat the above test both ways.
    If it still feels nice and smooth, adjust some more.
    Back out the adjustment if the tyre rubs on the radius arms or if you detect any sign of roughness from the cv.
    Note if the cv is worn the roughness may be due to it rotating further onto the wear steps. This can be fixed by "blue printing" the cv's but that is for another thread.
    If you have managed to gain significantly more lock, you may find the tyre will rub on the radius arms when the suspension is not at normal ride height i.e. a wheel pushed up, or drooped due to the uneven track surface. If you don't like the tyre rubbing (noise or possibly feel through steering, back the stops out a bit next chance you have.
    Also try to avoid using full lock when reversing up hill as per my previous post.
    Edit I see you have standard wheels I was just worried you might have wheels with more negative offset and with standard tyres. One reason people change to wheels with more negative offset is so they don't have to back out the stops and loose turning circle because larger tyres rub on the radius arms.
