Results 1 to 8 of 8
Thread: Defender 110 - auto?
    Ex-Cop Guest
    G day guys, I just arrived on the scene, and am looking at purchasing a TD5 110. This dont come in auto, my question was- has anyone fitted auto in these? If so what did u use?
    Thanks in advance for input
    TD5 comes with an auto in the Disco but this would be extremly difficult to fit to the same engine in a Defender as the ECU control unit which also interacts with the auto box would have to be replaced. Trouble is the looms are different lengths etc and matching it all up would be a nightmare.
    Big project......
    It is possible to fit an auto to a 300 TDi Defender though and there are a number of examples getting around.
    Melbourne, Australia
    I am also looking for an auto TD5 Defender 110, so if anyone knows of someone who does a good conversion, please advise! [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    tempestv8
    May 2002
    Sydney, Australia
    G'day,
    John Davis Motorworks used to do them - so I guess now give Bruce Davis a ring in Sydney.
    LRH.
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Hmm, I will give them a call, although I suspect they only do TDi conversions, not TD5 conversions. I'd be happy to be proved wrong. :roll:
    Thanks!
    tempestv8
    Redcliffe, QLD
    tempestv8,
    the boys down at Ritter Automotive on Highbury Rd, Burwood have just completed a really tidy ZF auto conversion on a Td5 Defender 110. It's a full mechanical set-up, no computer control at all!! Apparently, it goes really well!!
    Wow defute,
    Thanks for the info. I suspect they just used the non electronic ZF gearbox from the older TDi or V8 on a Series I Disco or some such.
    Must go and speak to them - since they are not all that far away from me. Any idea of pricing?
    Lawrance
    Redcliffe, QLD
    From memory, they used an early ZF 4 speed auto case and built into it all the Td5 Auto goodies to allow it mate upto the Td5 engine and withstand the increased working loads. They connected a mechanical kickdown cable from the Auto to the Electronic Throttle Pedal and specially constructed an Auto Fluid Cooler which is mounted behind the grille to keep the whole system cool.
    From all accounts, it's a very good conversion. Not sure of cost though. Give Owen a call - (03) 9808 0266.
