G'day again
Still struggling with the re-set of the rear springs. Worked out how to compress the springs (i.e. read the green manual, when all else fails, read the instructions dummy!) but now not sure what equipment I'm working with.
I've replaced all the shocks with Monroes to original specs, but the rears are virtually at the end of their extension travel. I know they'll compress when I get the springs properly set, but I'm worried about my shackles.
I haven't changed the rear shackles since I bought Sandie and I'm worried it might have been fitted with the extension shackles, in which case
1. would I need different shocks
2. what is the correct spring setting distance
I guess the only way to be sure is if someone could answer the above, and also give me the dimensions of the original and the extension shackles. At least that way I'll know which I have.
Thanks for any help
Richard
