Results 1 to 10 of 22
Thread: perentie isuzu fan belt
    Sorrento Victoria
    can someone please tell me the fan belt size on the perentie isuzu- the numbers on the old shredded one are unreadable- i ordered a new one the other day which was a 15A1205 but it's way too big and a 15A1185 which others have quoted will be too big too. I'm assuming the perentie's have a different size belt to the county isuzu?
    Sep 2010
    adelaide
    Quote Originally Posted by mattmac View Post
    no power stearing = smaller belt. i think you may have to take the bits in and do a guestamate
    WA
    Quote Originally Posted by 85 county View Post
    umm - no. PAS is driven from the timing gears...
    Feb 2012
    Parkdale, Melbourne
    What is the alternator setup?
    Crank, Water pump/fan, alternator make up the belt AFAIK.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Hay Point
    Genuine Isuzu part number for the Perentie is 1136713400 or BX45 is another number. Should be the same belt as the civvy version unless something has been changed
    Cheers......Brian
    1985 110 V8 County
    Sorrento Victoria
    fan belt
    Got it sorted- picked up a bando RPF5460(15A1185) which is actually 17x1210mm- strange how they label it 15A when it's 17mm.
    Aug 2011
    Wyalkatchem
    My Perentie belt on vehicle as purchased is a Bando RPF 5470. With the numbers 17X1170Li. The belt is nearly stuffed and I have run out of tension movement on the alternator arm. I did get a 17A1160 but was too small. Paul.
    Aug 2011
    Wyalkatchem
    I am running a B46 as a temporary measure. Paul.
    Aug 2008
    Perth, WA
    Would the size difference be due to AC in a County, not sure as my aircon is currently in bits in the shed so I can't check
    Aug 2011
    Wyalkatchem
    I just fitted a Dayco 15A1220C. Tight to get over pulleys but tensioned up well. Paul.
