Results 1 to 10 of 23
Thread: Spare wheel carrier - 130 trayback
    Nov 2012
    I'm looking into getting a Trayon camper in the future and I'm trying to determine what to do with the spare wheel(s)
    Has anyone had any experience with something like this: Swing away spare wheel carrier for Haymen Reece coupling
    If it's braced well and doesn't rattle/bounce would it be a viable solution? I have to say I've never seen something like it locally.
    '11 Def 130 "Henry"
    South Sydney
    You give away your ability to tow, and if it's going on a tray back ute the tray would probably stick out further than the tow bar anyway, so it wouldn't fit.
    I certainly wouldn't be using the tow bar extension they have on it, and I highly doubt it would be legal over here.
    Sussex Inlet. N.S.W.
    Most Trayon campers I have seen, including my mate's has the spare wheels mounted on the headboard of the tray. There is usually a gap between the back of the cab/headboard and the front of the camper unit.
    Jim VK2MAD
    '17 Isuzu D-Max
    Nov 2012
    Quote Originally Posted by jx2mad View Post
    I've seen that too, the problem is the camper I'm looking at is already 2100mm long. That's the same length as my tray so unfortunately no room for a spare against the headboard.
    Quote Originally Posted by MR LR View Post
    You're correct, the one in the link wouldn't work because of the tray. The idea came from a fabricator who saw my setup and suggested this rig. He has made them in the past and it would be a custom job to suit my vehicle. The concept is the same though.
    I rarely tow and if I do it's just locally to the river with a dinghy. I'd be prepared to lose the tow capacity when utilizing the carrier.
    Another option is to carry the spare on a rack over the cab, but I need that space for a roof top tent. (We are a family of four so need the extra bed space!)
    I think from memory the specs allow for up to 150kg to be placed on the towbar and if I keep to within that it should be OK?!
    '11 Def 130 "Henry"
    TonyC is offline Wizard Silver Subscriber
    NE Victoria
    32.83 MB
    Have a talk to Rijigij on here, he does a carrier for a 130 and seems able to do custom/accommodate mods to his designs.
    Home - Rijidij Off Road
    Tony
    Apr 2011
    Windsor NSW
    tray lift
    Hi I have just ordered a new puma 130 and the tray will be lifted sufficiently to let the spare be carried underneath the tray as all Toyotas do for eg. I have done this for exactly the same problem you mention re camper on the tray and no room for the tyre.Good luck
    I forgot to mention that my mate has had runners fitted so the camper sits above the tray with storage underneath
    Jim VK2MAD
    '17 Isuzu D-Max
    Jan 2008
    NSW near Queensland border.
    The RFS had a Defender as one of their support vehicles with the spare tire mounted on the bullbar. Do not know if that is still legal.
    VladTepes's Avatar
    Bracken Ridge, Qld
    I don't think that's ever been legal.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    this was my solution.
    More info here
