Thread: transfer case oil problem!
    Padstow NSW
    I ve just finished changing the oil in the disco's t case and found that
    it is quite burnt and very metalic!
    has anyone got any ideas for me? am a little worried at this.
    oil has only done 10 000k's :?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Ouch!
    not good by the sounds of it
    is it noisy?
    what type/brand of oil did you have in it?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Padstow NSW
    Thats the thing! there is no noise at all, factory gear lash, no leaks
    and all the teeth i can see are ok? I use shell 80-90w?
    Jun 2003
    Launceston, Tasmania
    When I first did an oil change after getting my landy (although it is a bit older than yours), it was quite thick and very metallic.
    I was assured by a mechanic that it wasn't unusual to get that from regular use. That didn't really stop me worrying however.
    As for the burnt colour, how much oil did you get out? as much as you put in, or noticeably less?
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Padstow NSW
    IT lost bugger all maybe 100mls?
    I ll keep going and check it at 5000k's and see how it going. :?
