you can if you have 7" long rubber fingers [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
you just undo the 6 odd bolts, then twist and separate.
it is wayyyyyy easier to remove the pedal assembly take my word for it....
gives you a good chance to clean up the firewall under the pedal mount as well.
dont forget to seal it with a gasket or silastic when you put it back.
the slave cylinder is an easy task.... well almost [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
