Results 1 to 4 of 4
Thread: 3.5 V8 Compression Ratio
    malrv1 Guest
    Hi Will a 9.35:1 3.5 V8 run on our 91 RON unleaded OK?? I know in the UK there standard unleaded is 93 RON.
    May 2003
    On The Road
    The filler cap sticker on my hi-comp 4l says premium,,,
    Melrose SA
    I run mine on it without issue if it pings just change the timing slightly
    It doesn't perform as well as the higher octane fuel but it works fine
    Aug 2010
    Sunbury, VIC
    Mine ran fine on 91, but with 350,000KM on it, I doubt the compression was as high as it was when it left the factory...
