Thread: 300TDI cooler/pump upgrade long term reviews/issues
    Aug 2011
    Melb
    Hey guys just wanting to hear from all you guys that have had the intercooler/ injector pump upgrade on 300tdi for a few years and any issues and you think it may have caused. just wondering what the longer term issues may be once you got the egt within the acceptable range. Thanks
    Sep 2011
    I put an allisport uprated in about a year ago along with fuel pump tweek. Made a massive difference to the all round driveability, especially Off Road.
    Only issues I have noticed is that after about 6 months the amount of smoke on start up/through the gears increased. Need to play with the smoke screw when I have time. Other than that.... All good.
    NSW far north coast
    Had the pump pushed to the max (have to back off so as not to exceed 720*C) for about seven years now, stock IC, big exhaust and car is always heavily loaded as it's used for work.
    No issues to report yet.
    Feb 2012
    Parkdale, Melbourne
    Quote Originally Posted by rick130 View Post
    OEM radiator? Or upgraded? What does your temp gauge hit?
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    NSW far north coast
    Yep, OE rad and it gets too hot, has seen close to 110*C once or twice, hopefully a new rad with a Redback core for this summer.
    Still original head gasket at 315,000km. (should be done as a precaution soon, too)
    Bear in mind this is in a heavily loaded Deefer too.
