Results 1 to 10 of 24
Thread: Runva Hyd winches any good?
    Dec 2009
    Williamstown, Barossa, SA
    Hello all... I've been looking at Hydraulic winches as I have a truck gearbox with a sizeable dowty pump on the side of it that as some of you will know is going into the 101.... I've been looking at the various s/h winches on Gumtree and Ebay but then stumbled on the 10000lb Runva Hydraulic Winch. I plan to mount it under the floor at the rear of the 101 and figure that 10000lb is plenty because that doubles with a double line pull.... The advert says 'lifetime Guarantee' and at $1350 it has to be a better or comparable option to a tidy S/H Superwinch at $1500.... Your thoughts and opinions would be appreciated be they +VE or -VE. Cheers all. Simon.
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Dec 2009
    So, no one has had anything to do with these?? Kinda tells me that they're no good then!
    Quote Originally Posted by Sitec View Post
    That might not be the case. Maybe most people aren't set up to power a hydraulic winch.
    Feb 2010
    Wangaratta
    I've got a runva 12v electric 9500lb winch on my disco 2. I've used it twice and it worked very well.
    Free Again Thanks Dan
    No not had any experience in the runva , But a mate of mine has a 4x4 w/shop here in vic and he is a authorised agent and repair agent for them , he was a tigerz repairer but got sick of fixing winch.s.
    He actualy says they are the best chinese which he has seen and worked on He has had very little problems or need to fix on them well the electric ones any way
    If you want pm me and ill send you his contact details and you can ask him your self
    Geelong, VIC
    Mmmm. Maybe I've found a use for that Isuzu PTO drive and pump sitting in my shed
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Moruya Heads/Sth. Coast, NSW
    I've just bought a 15,000lb Runva Hyd. winch for my truck (inter ACCO), haven't finished setting up yet but the construction is solid and the accessories supplied seem to be first class, will let you know how it performs in a day or 2.
    My biggest problem is setting up the hydraulics off the PTO pump which powers the 5T. Hiab crane, seems I need to setup a relief valve so as I can by-pass the Hiab setup, you will more than likely have to install a relief valve as well, Regards Frank.
    P.S. when buying a winch don't go by the advertised 10,000lb cap. go by the SWL of the cable supplied, in the case of the 10K. you will find that the SWL of the cable is around 1T. BTW I paid $1078 for my Runva 15K winch which includes freight of $99.95 weighs 85kgs. if you want the name of the seller reply here or send a PM.
    Try this mob for your 10K hyd. winch, just a bit cheaper,
    10 000 LBS Hydraulic Winch Brand NEW in Loddon, VIC | eBay
    Regards Frank.
    Oct 2012
    FNQ
    On our Isuzu truck we run a 22000 lb hydraulic winch which runs off a spare spool valve of the crane control.A wing nut holds the lever in the forward or reverse position .Works very well with no other valves needed
    Frank, Since you seem to ALWAYS bring up the cable size VS SWL on winches. Could you tell me #1, are you referring to LIFTING? and #2 are these and any 4x4 winch rated for LIFTING?
