Are they glowing orange without the indicator switch on, or are the glowing orange steady when you indicate left or right. What happens when you use the hazard lights? When they glow steady orange - are BOTH sides on - or just one side?
My guess is that they are glowing solid when you indicate left or right, and that the correct side is lighting up. The only issue is they are not flashing - just staying on. There's no magic electronics in the PUMA, a plain old flasher relay does the business, I'd guess that has developed a fault. (My old td5 did this because of a dry solder joint - 10 seconds with a soldering iron fixed it.)
  Reply With Quote Originally Posted by bemm52
