Thread: Copper or Steel brake lines?
    Jul 2013
    ravenswood, Western Australia
    Hi every one,
    I am about to start the process of replacing the copper brake lines on the series 2 i am restoring.
    A quick question to get me started on the process:
    Am i able to replace with copper or do i have to use steel now?
    cheers for your time and help
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    You can't legally use copper, but you can use approved copper alloy tubing that does not work harden and crack.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    As mentions, straight copper is a no no. Drop into your local brake shop and get the correct copper alloy tubing of them - it is quite cheap, and easy to work with. A cheap tube bender off ebay for a few dollars and a flaring tool, and you are good to go.
    Jul 2013
    awesome guys thanks for the info, will post photos of the result
    brake lines
    I think you need a flaring tool that does double flares to be legal. Regards John
    Narrogin WA
    Check with your local licencing authority before you buy it - some allow it, some don't,
    Cheers Charlie
    Jul 2009
    S.E.Qld
    I had some copper brake pipes fitted.I had to provide proof that they were of the approved type.That I could not do. Replaced them with steel. .W.
