It will be a L series Diesel. K series are the petrol models.
Usually when the head gaskets blow on these it is due to a poor cooling system service history and the head gasket which is a MLS gasket rusts and blows. Its not a common issue with these engines.
Apart from the normal head pressure surface checks with a blown gasket, I would change the glow plugs while the head is off and replace the timing belts with quality name product like dayco.
I have one of these with 213000km and my brother has one with 330000km on them and they both still run well. Biggest issue with these is the IRD unit and if you dont need 4wd you can remove the tail shaft and run it as a front wheel drive.
if a blown head gasket is the cause and with the symptoms above am I looking at anything else requiring repair?
